03-19-2010, 12:59 PM   #1
Flash and Kx
With an external flash and the Kx, is it possible to use a flash like the Metz 48 wirelessly without the built in flash firing?. I read the manual with no luck and probably just need to read it again.
03-19-2010, 03:50 PM   #2
enoeske's Avatar
Yes, but you need to buy some radio triggers. Otherwise, how will the camera tell the flash to fire?
03-19-2010, 09:46 PM   #3
So I guess an easier way for what I was thinking, is just to mount the flash on the camera and bounce it off something? I'm very new to this so pardon my ignorance. The Kx does work with an external flash wirelessly, correct? It just needs the on board flash to fire as a master?
03-20-2010, 01:38 AM   #4
FattyMcJ's Avatar
QuoteOriginally posted by Gregor Quote
Yes and no. It CAN work that way, but doesn't have to.
You can choose to use wired/wireless flash triggers too.
Check out this thread HERE for some great information and great visuals of what the product looks like (other similar products will...look similar lol)
Hope that helps.
03-20-2010, 07:35 PM   #5
dnaseigel's Avatar
If you go to the custom settings menu in the K-x and find the function that says "Flash in wireless mode", select setting #2, then fire the camera. (Of course your pop up flash will be up). Your Metz 48 flash has a wireless P-TTL function (I can not recall how to activate it without one in front of me) and when the camera fires the on board flash will not fire...only the remote Metz flash will. The sequence goes like this
Camera flashes to tell the remote flash that it needs to fire.
Remote flash fires back to confirm it will flash and measures how much light will be needed.
The camera flash fires to give the command to the remote flash to fire.
The remote flash fires individually during the exposure.
This sequence will occur in a very short period of time (1/5000 to 1/10,000 sec.) so the way to test that it will work is as follows: Put a subject directly in front of the on camera flash, and put a larger subject behind it. When you take the photo, look at the shadow on the larger subject behind the one directly in front of the flash. The position of that shadow will tell you if the on camera flash fired during the exposure or not.
Good luck and let us know how that goes.
03-22-2010, 02:26 AM   #6
tokyoso's Avatar
just set your k-x to use on cam flash as control only, not master... its in your menu somewhere. read both menus carefully... just a matter of RTFM really..
03-22-2010, 09:56 AM   #7
QuoteOriginally posted by dnaseigel Quote
Very cool! Thank you much.
camera, flash, kx, pentax help, photography
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 09:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
