03-21-2010, 08:53 AM   #1
Question
I have an old film pentax (MZ-30) with 2 set of lenses SMC Pentax Fa (35-80 and 100-300). Is there any way I can buy a cheap DSLR body to use with these lenses? I am no expert of advanced user, I just need the camera to work and hate wasting what I have. Can anyone advice?
03-21-2010, 09:02 AM   #2
Pentax KX or older body. KM
03-21-2010, 10:07 AM   #3
Yes. All hose lenses will work with all the newer pentax dslr body. From the ist go the k7
03-21-2010, 11:39 AM   #4
sterretje's Avatar
Just a note:
The surface of the sensor in a Pentax dSLR is smaller than the surface of a film negative. Therefore your lenses have a a field of view (FOV) that is smaller. As a result, the FOV at 35mm becomes the equivalent of a 35x1.5 (~50mm) and the FOV at 300mm becomes the equivalent of 300x1.5 (~450mm).
So you might need to consider the purchase of a wider lens.
03-21-2010, 04:24 PM   #5
GoremanX's Avatar
As others mentioned, yes you can use your existing lenses.
Just a quick note: that's the most useless thread title ever.
camera, lenses, pentax, pentax help, photography
A Question for Everyone Fl_Gulfer Photographic Technique 34 11-02-2010 03:33 PM
question Danny Delcambre Troubleshooting and Beginner Help 10 01-02-2010 02:12 PM
A Question about K-7 oxidized Troubleshooting and Beginner Help 9 12-17-2009 09:56 AM
PP Question AOski Troubleshooting and Beginner Help 11 05-13-2009 01:26 PM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
