03-21-2010, 10:11 AM   #1
Acid's Avatar
Hi! Some beginner questions form Deutschland (DSLR)
Hi everybody!
first: sorry for my bad english!
I just get the the k-x..
and there are some questoins i've got.
is it possible to use one of this objectives with the k-x.. (adapter!?)
Planar is from Rolleiflex SL35
Rest Canon AE-1
and if its possible to turn off this ****ing bright blue LED.. awful when its dark..
greets andi
edit..: its possible to mount the planar, but not realy save.. fi you screw to much its droping out..
03-21-2010, 10:21 AM   #2
Moderator Emeritus
Welcome to the forums and congrats on the new camera.
Yes the LED can be shut off. It has 3 settings. Page 254 of the English manual under "Power Lamp" in the index. Item 20 in Custom Settings.
As for these lenses. Few can be used on a K mount body. The most common that can be used are K mount to M42 screwmount, also screwmounts like M39 with the correct adapter. But with other brands, there are issues with register distances to the sensor etc. This is also very true in other brands of cameras. The lenses need major modifications to make them work. The issue is with different register distances (Canon being shorter) that you would loose infinity focus and basically only have a close focus lens. Have a look at this post.
03-21-2010, 10:33 AM   #3
Acid's Avatar
thaks.. just turned the light off
is here also an adapter for the planar objektive?
and will the focal lenght be more or less then before with the canon objektives?
03-21-2010, 10:38 AM   #4
Moderator Emeritus
What's the mount on the Planar? If it's the first photo, then no. If it is a screw on lens, then probably. Forget the Canon lenses. You can't use them on Pentax. In fact you can't use them on Canon either.
03-21-2010, 10:50 AM   #5
Acid's Avatar
hm ok.. so i should buy some new..
i like fixed focal lebgths.. do you now somethig cheap? i don need this auto focus.. and all the other extras.
one 135mm and one 15mm (no fish). perhaps a makro to.. some ideas what i should look for.
03-21-2010, 10:52 AM   #6
Moderator Emeritus
Have a look through this: Screwmount data base. All you need is a genuine Pentax M42 to K mount adapter (around $30 in the US) and you can use all these wonderful lenses. Maybe the best value is the SMC Takumar 55mm f1.8 at around $50.00 here.
03-21-2010, 10:54 AM   #7
Moderator Emeritus
There are a lot of posts but good info here as well
Takumar club
Off Brand Club
K club
03-21-2010, 10:59 AM   #8
Acid's Avatar
ok.. then ive got alot to read now i think.. its hard for me as a beginner with D-slr to get through all tihs stuff.
thanks for your help.. see you sooner or later.
lg andi
03-21-2010, 08:37 PM   #9
Marc Sabatella's Avatar
See also the lens review section of this site. Of the manual focus lenses, the A, M, and K series lenses all mount with no adapter. The A series supports full autoexpousre; the others require stop down metering (see the sticky thread in this forum on using manual lenses). the m series is probably the most popular.
Beginner questions. magnum1 Digital Processing, Software, and Printing 6 08-10-2010 09:48 PM
Beginner DSLR Exercises Grazy81 Troubleshooting and Beginner Help 13 08-09-2010 01:05 PM
GREAT Beginner DSLR owner tips kiamon Pentax DSLR Discussion 10 06-03-2008 03:42 PM
Pentax/DSLR Beginner Seeking Gear Advice lastdodobird Troubleshooting and Beginner Help 24 11-02-2007 06:01 AM
some basic (beginner) settings questions Cloudy Wizzard General Talk 2 10-27-2007 01:25 AM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
