03-23-2010, 12:16 AM   #1
Oh no! I got a lens that won't fit!
So this is probably a total schoolboy error, but I got a Viv lens off ebay. It's a P/K-A mount lens and supposedly good to go on a pentax dslr. But it's not. It won't fit!
Have i made a stupid error in mount types? I hope I can get some help here.
Here's a pic of the lens mount.
Oh by the way, I have a K-7
03-23-2010, 12:39 AM   #2
RollsUp's Avatar
You need to cut/grind part of the flange or remove it altogether if you want to use it on your K7.
Pentax Digital
03-23-2010, 12:41 AM   #3
Your right about it being a Pentax mount, however it won't fit your digital without a modification.
If you take your kit lens, and compare the mount with that one you most likely see that the black plastic protecting the tab sticking out is bigger than it is on the kit lens.
You'll often find that plastic piece is held on by 3 or so screws. If it is remove it, and use a file or a dremal to try matching the plastic piece on your kit lens.
I'd do it away from either lens and your camera, so you don't get shavings in them.
Then screw it back on, and try it.
If you can't remove that plastic piece, tape everything off and carefully fine it down. While still on the lens.
03-23-2010, 12:58 AM   #4
OK, sounds fun.
I see what you're talking about, that plastic is indeed much longer than the one on the kit lens. Good thing I have some mini screwdrivers around here.
Now, where's my Swiss army knife? BRB
03-23-2010, 01:07 AM   #5
OK, so the offending piece is actually made of metal and is going to pose an obvious problem in terms of modification.
Am I safe to just remove it and leave it off? It doesn't seem to hold anything else in place and there's nothing loose without it...
What do ya reckon? Am I in the clear?
03-23-2010, 01:15 AM   #6
I just took off the offending piece and put it on the camera, fits well.
One problem, everything's really dark... What's wrong?
03-23-2010, 01:20 AM   #7
TOUGEFC's Avatar
QuoteOriginally posted by Ouroboros Quote
Did you remove the lens cap?
03-23-2010, 01:27 AM   #8
Yes but I did in fact have the aperture set all wrong.
More issues, The flashing "F" what the hell is it and how do I get rid of it?
Oh man, this is more difficult than I thought.
03-23-2010, 03:29 AM   #9
chrisb3's Avatar
Did you set the K-x to allow for manual Apeture setting? It's on the last page of menu settings.
03-23-2010, 04:28 AM   #10
Alright! Got that last page on the settings to allow manual aperture, that was the last part tripping me up. Got it working and lookin good!
Thanks for the help everyone!!!
Much appreciated
03-23-2010, 05:59 AM   #11
Ira
Much appreciated
Did you set the Green button for Tv shift?
What you want to do is set the camera to M, input the correct focal length every time you put a manual lens on there, and shoot like this:
Select your aperture and focus, and hit the Green button to lock in the correct shutter speed. (You don't have to hold it down; just hit it once.) You may want to focus wide open, THEN go to the aperture you want, and then hit the Green button.
Don't use Av mode on the camera--it will only work as your lens being wide open, regardless of how you set the lens. Av mode will still meter correctly, but like I said, it will only do so at the lens's widest aperture.
03-23-2010, 07:28 AM   #12
pbo
pbo's Avatar
__________________
That's overdoing it - just put the lens aperture ring on "A" and shoot as you would with any other MF lens (F-- will disappear)
03-23-2010, 07:37 AM   #13
aleonx3's Avatar
QuoteOriginally posted by pbo Quote
You can see how easy we forget, the first picture shows that it is an A-lens!! funny...
03-23-2010, 07:51 AM   #14
Ira
OOOPS!!!!!!
The mind is the first thing to go.
03-23-2010, 08:10 AM   #15
I shoot another brand of digital, which requires me to either remove that tab altogether, or grind it flat. So I've just removed it with most lenses, and never had a problem.
However there are some people here that'll tell you it'll cause internal reflections.
If it gives you good pic's just leave it.
camera, error, lens, mount, pentax help, photography
Will this lens fit my kx? 4ngi3 Troubleshooting and Beginner Help 13 06-30-2010 11:33 AM
Will this lens fit my kx ??????? spanky66d Troubleshooting and Beginner Help 7 02-18-2010 03:23 PM
So who won the Lens off Ebay?? Fl_Gulfer Pentax SLR Lens Discussion 6 12-06-2009 08:56 PM
Would this lens fit a K20D? mattmiles Troubleshooting and Beginner Help 10 10-25-2009 05:55 PM
Ooops, won 2 135mm m42 lens, which one should I keep? reknelb Pentax SLR Lens Discussion 2 02-25-2007 11:12 AM
All times are GMT -7. The time now is 12:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
