03-27-2010, 04:41 PM   #1
Ack, won't go to 100 Iso?
I set my K-X on expanded Iso and it can do the 12800 but not the 100 any reason?
(side question... the camera doesn't do well with AF in dark places right?)
03-27-2010, 04:49 PM   #2
You must have the "D-Range" enabled. It's a function that gives a greater dynamic range to your pictures, but, once set, you can't use ISO100.
03-27-2010, 05:07 PM   #3
QuoteOriginally posted by flyer Quote
Oh ;( that sucks... I think... 100 iso or GDR?
03-27-2010, 05:07 PM   #4
Ira
On the KX, you have to turn off Highlight Correction.
You can still enable Shadow.
03-27-2010, 05:10 PM   #5
Pablom's Avatar
QuoteOriginally posted by NecroticSoldier Quote
that's an understatement
03-27-2010, 05:34 PM   #6
QuoteOriginally posted by Pablom Quote
I carry an LED flashlight anytime I do a night shoot because of this.
03-27-2010, 05:54 PM   #7
Ira
When Yves says you "must" have, he means you SHOULDN'T have, but you do.
03-27-2010, 06:35 PM   #8
That's true... but I'm not sure if I have it on or not...
03-27-2010, 07:14 PM   #9
Ash
Community Manager
Ash's Avatar
Check your manual - it should be a couple of buttons away from disabling - on the K20D, it's obtained by pressing Fn, then ISO on the 4 way controller, and press Fn again to enable/disable the function.
03-29-2010, 05:52 AM   #10
Ira
Did you ever figure this out?
03-29-2010, 07:35 AM   #11
Wondering why Expanded ISO is not the default?
Do you guys keep this setting checked off on your camera?
Lastly, is there any downside to picture quality (outside the normal effects of increasing /decreasing ISO) when you push the ISO outside of its normal range? Thanks.
03-29-2010, 11:33 AM   #12
Ira
QuoteOriginally posted by Marc Quote
I have it expanded, because I like to go to 100.
I guess they have it off by default for people using the automated Program and Scene modes. If you go to 100, you need longer exposures and wider apertures, and if you go to the highest ISO, you get the noise.
They set everything for default for what they figure will be the initial settings for the majority of people first opening the box. Most people don't initially use non-auto lenses either (or ever), so the default is "Use Aperture Ring Not Permitted."
03-31-2010, 07:22 PM   #13
Nope... I feel sorta dumb now LOL. This technology stuff confuses me! (THROWS AWAY K-X) ;D K1000! YAY!
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
K-x Won't Go To ISO 100? wallyb Pentax DSLR Discussion 9 11-15-2009 02:37 PM
K7 - No Iso 100? noVICE Pentax DSLR Discussion 6 09-15-2009 06:09 PM
K7 ISO 100 ?? how to kmanlaker Pentax DSLR Discussion 4 08-08-2009 09:18 AM
iso 100 or iso 200 kiwao Pentax DSLR Discussion 8 03-05-2009 01:02 PM
All times are GMT -7. The time now is 03:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
