03-28-2010, 07:11 PM   #1
K-X Video?
Says here... in the manual if a high temperature is reached while filming a video, the video will be terminated to prevent any damage to circuitry.
Umm... so if I put maxed quality video... how long would the video run for? (without heating the heating termination thingy)
I remember I read somewhere... but I forgot... sorry to ask again.
03-28-2010, 07:37 PM   #2
from the manual, pg 151
You can record movies continuously up to 4 GB or 25 minutes. When the SD
Memory Card is full, recording stops and the movie is saved.
03-28-2010, 07:39 PM   #3
Long enough to fill my 4GB memory card It will display the temp warning though, but not enough to be so hot that it will auto shut down.
I live in a tropical country, it's usually 32C here. So I guess your camera will do better there in Ontario
03-28-2010, 07:48 PM   #4
Okay, now that IS strange... I recorded our band practice... only lasted around 5 mins on max setting. I did not touch the button. We jammed for 15 mins.
03-28-2010, 07:59 PM   #5
QuoteOriginally posted by NecroticSoldier Quote
did it display the temperature warning icon? or just stopped recording?
if it just stopped recording, maybe your memory card isn't fast enough
03-29-2010, 05:17 AM   #6
agreed with RolloR, sounds like you ran out of buffer and the card could not keep up, time for an upgrade!
03-29-2010, 05:31 AM   #7
Ira
You didn't have LiveView on by any chance, did you?
03-29-2010, 07:25 AM   #8
is it possible to record video without using liveview, if so, how?
03-29-2010, 12:26 PM   #9
Ira
QuoteOriginally posted by justDIY Quote
Good point--I don't even know.
Probably just by turning off the LCD, which reduces heat.
03-29-2010, 03:55 PM   #10
My card is rated class 10... it should work... I took the 8gb over the 16gb because of the speed. Could not be the memory card...
camera, pentax help, photography, video
K-7 Video Frame Exposure Errors "flashes in video" steveoliver Video and Pentax HDSLRs 4 06-02-2010 07:36 AM
The K-7 Video Thread (Dare I say Video Club?) Urkeldaedalus Video and Pentax HDSLRs 33 01-05-2010 10:49 PM
Will using the video-out when in video mode help conserve battery? greenless Pentax DSLR Discussion 2 12-14-2009 02:49 PM
Video but not the K-7. Looking for advice on a video camera Peter Zack Photographic Industry and Professionals 12 09-11-2009 05:24 PM
K-7 with 16-50, video from WhatDC, video from pentax Isaac314 Pentax News and Rumors 10 05-21-2009 11:11 AM
All times are GMT -7. The time now is 11:35 PM. | See also: NikonForums.com, part of our network of photo forums!
