Originally posted by vandamro So I have been doing my reading on CP filters. The big question I have now is about these step up and step down adapter rings. Certainly, that would save money from having to buy so many filters.
I have a lens with an 82mm thread size. Can I use something smaller? How much smaller can I do without causing vignetting? Also is there a limit on how much you can step down?
Any advice would be appreciated.
You don't want to step down with filters, you want to step up
. If you step down then it's like the photo above, you're putting on a filter that only works for part of the frame. What I have, is step up rings and expensive filters in my largest filter thread. By having it in my largest filter diameter thread it covers the biggest lens I have, and by using this
cheap step up set from China, I can use that same filter on all my other lenses by just adding this.
A "but" is if you need to focus very close to the lens, for example macro. Having that set on your lens adds a bit of an inverted cone onto the end and that might be an issue if you're trying to focus superclose. The slight caveat I can foresee here might be full frame lenses on APS-c (digital) bodies. Since you're only using part of the full frame 'width'
in theory you can use a step down with that without the coverage suffering. I havn't had to do this myself though so I can't honestly give you a reliable answer on that.
