03-31-2010, 08:59 AM   #1
lens ?
New to SLR but I now own a Pentax K-X. Friend has Pentax K-1000 film camera with 28-70 3.5/4.8 lens and 70-200 4.0/5.6 also 2 flashes and some filters he wants to sell for $100. Would this be something to consider?
03-31-2010, 09:06 AM   #2
You can check the lenses out: Pentax Lens Review and Specification Database - Main Index It also contains average prices so you can check if the price is fair.
Be careful with the flashes as the voltages might be to high and blow your Kx. Read up on trigger voltage and check the flashes against it; you might always be able to use them wireless.
Not knowing the exact lenses makes advise a bit difficult, but I don't think that I would not hesitate. And in your shoes, it gives you some extra flexibility as well, even if the lenses are not the very best that money can buy (as said, I don't know). At least you will get experience with different focal lengths.
Note that those are probably manual focus lenses.
PS Welcome to the club
03-31-2010, 09:15 AM   #3
QuoteOriginally posted by lottolearn Quote
It's something to consider. If these lenses are Takumar-A lenses I don't know that I would go $100. Inspect them carefully, make sure there is no zoom creep (best discovered if the zoom ring feels sloppy), the focus is nicely damped feeling, etc. If they are Aftermarket lenses (3rd party) beware of the Ricoh Pin (do a search on the forum) before mounting any of them on your camera. The flashes may or may not be usable on your Kx. Look for corrosion in the battery compartments. Of course if they work and you want to play with radio triggers, these cheapo flashes can be a great way to go. If you want to Use or resell the K1000, make sure the meter works, no rust inside, etc. Chances are pretty good that the seals will need to be replaced. That's something you can do yourself if desired as you can buy seal kits off of ebay.
Buying used kits is a great way to build up your arsenal if you know what you're looking for and at. The lens and camera databases here are pretty extensive and informative. Use them to your advantage.
Good luck and welcome.
03-31-2010, 12:34 PM   #4
lens
Thanks for all the information. The 28-70mm lens is a tokina SD , 52 and one flash is P536TLC5. Not finding a brand on the 70-200mm. with cable to use with a tripod. Will continue to research before buying.
03-31-2010, 09:23 PM   #5
For 3rd party lenses: PentaxForums.com Third-Party Lens Review Database - Main Index
The tokina? PentaxForums.com Third-Party Lens Review Database - MF 28-70mm. f3.5-4.5. SZ-X 270 SD
PS I see that I made a mistake in my previous post
.... , but I don't think that I would not hesitate.
That should be 'I think that I would not hesitate'
camera, lens, pentax, pentax help, photography
All times are GMT -7. The time now is 11:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
