Originally posted by DSLRnoob
Hello,
Does anyone know what the continuous shooting speed would be for a K-x when shooting Raw+Jpg? Would it be similar to the 4.7 fps for jpg only?
Thanks.
Bill
The K-x has a small buffer size: as soon as the buffer is full (5 RAWs), the fps will slow down drastically in Hi mode, even with a class 10 card. The problem will be worst in RAW+ mode depending upon the JPEG file size.
In Hi continuous mode, you need to select JPEG file size that allow for its continuous tranfer to the card: e.g, if your JPEG file size is 2 Mb, the car transfer rate must be at least 4.7 times 2 Mb/s.
The K-7 with its larger buffer (15 RAWs) does have the same problem: as soon as the buffer is full (or near full), the shooting rate does drop sharply.
An alternative is to use the Lo continuous shooting mode (2 fps with the K-x). The buffer filling is slower and your may take some continuous shots for a longer period, with the same camera and card.
Hope that it wil help...
