Originally posted by MsGilbert Thanks Wheatfield. I also discovered you have to take the motor drive off to replace another battery in the camera body. I hadn't realized it comes off.
If you have a motor, there are a couple of things you need to know.
There are two screw in plugs that go into the bottom of the LX, one is under the film spool, the other is under the take-up mechanism.
If you are going to use the camera without the drive in place, you need to have those plugs in place or else the camera isn't light tight.
The plugs screw into a couple of sockets in the motor drive itself for storage when the drive is mounted, so make sure you have them if you sell the motor separately.
