04-05-2010, 08:59 PM   #16
Krishna, in the picture below, if I didn't tell the camera to use the center focus point to focus on the eye, then it would focus on the leaves in the forground and we wouldn't be able to see the eye .
04-05-2010, 10:21 PM   #17
It's probably worth noting, since you are comparing it to a canon, that the k-x doesn't have the in-viewfinder focus point indicators that the canon does. It doesn't affect the functionality of the camera too much once you adapt to it, (that's why everyone is saying to use center focus) but may be one source of your concerns.
04-06-2010, 06:47 AM   #18
Taking your inputs into consideration, took some more snaps to correct my focusing skills and uploaded for review.
04-08-2010, 02:22 AM   #19
kiwi_jono's Avatar
I was new to DSLR when I got my K-x (although have shot a bit of manual SLR) and I was finding it hard to get consistent focusing results on my subjects until I changed focussing 11 / 5 points to center point only (not multizone). Using a single point, I focus (half shutter press) with the center of viewfinder on region I want in focus then move camera to frame the shot I want and fully press shutter. Known as "Focus and recompose". Does not suit everyone and I'm sure the multipoint has its uses but certainly works well for me.
BTW - love the cats eye shot Ken!
04-08-2010, 07:30 AM   #20
One thing you might want to try in order to determine where your issues lie. Put your camera on a steady tripod. Take off all filters. Point your camera at a brick wall, but at something other than a 90 degree angle to the wall. Place a mark on the wall and spot focus on said mark. If you have a cable release, all the better. Shoot multiple shots at various lens openings. This will let you know if your lens is front-focusing or back focusing. It will also give you a practical exercise in depth of field.
04-08-2010, 08:38 AM   #21
i changed to center focus point since day 1 with my camera. At least for me is what i need in 99% of situations.
Ken that's a beautiful picture
04-09-2010, 06:55 AM   #22
As others have said center point focus and recompose. Manual focus with live view also works well for me.
04-09-2010, 07:31 AM   #23
Hello everyone,
Newbie Kx owner here just last January and after reading a few posts I would just like to ask is if you're saying center focus point are you pertaining to just one subject or can you also do that in a group picture (family gatherings, childrens party, etc...).
Thanks.
04-09-2010, 01:24 PM   #24
Marc Sabatella's Avatar
Doesn't matter how many subjects you are dealing with; the camera can only focus at one distance at a time. So in group setting, you aim somewhere between the closest and farthest person, and make sure you have a small aperture so that depth of field (Google it is you're not familiar with the term) will extend far enough in front and behind to get everyone in focus.
04-11-2010, 10:32 AM   #25
gebco's Avatar
I thought my kit lens was soft too. However, I have since adjusted the focus on my K-x and, so far at least, it seems sharper.
Edit: I don't think the OP's photos here show focus adjustment needed; they simply look OOF, and, in the case of the snake, overexposed.
04-11-2010, 02:40 PM   #26
jct us101's Avatar
Could you specify this focus issue, because my new Nikon D50 has the same problem, but every Pentax and Canon DSLR I've used can focus on multiple things at once. I'm assuming you mean because of the DOF rules, you can't focus on two different planes at once (since you don't have a tilt shift lens most likely)?
04-11-2010, 06:11 PM   #27
RioRico's Avatar
QuoteOriginally posted by jct us101 Quote
A lens cannot be focused at multiple points. Assuming its image field is pretty flat, it can focus on just one point in one plane at a time. With a tilt-shift system, that plane can be at an angle; otherwise it's parallel to the sensor or film. (Curved-field lenses are something else, but you hopefully won't run into many of those now.)
A camera that SEEMS to focus at multiple points, is reading the distance to those points, then applying an algorithm involving those distances and the aperture, to try to get them all within DOF range. Maybe we need a sensor that marks those points, determines a plane they're all in (but no more than 3 of them), and physically orients itself (and the lens) to be parallel to that plane. Don't hold your breath.
04-11-2010, 06:26 PM   #28
jct us101's Avatar
Well for example on my Rebel when I focus on something, sometimes 5 of the 9 AF points will light up red indicating that they've locked focus on different areas of the photo.
04-11-2010, 06:30 PM   #29
lurchlarson's Avatar
Make sure you are shooting at at least 1/60 or 100 if you are zoomed all the way in. Also try stopping down a bit.
04-11-2010, 06:39 PM   #30
rparmar's Avatar
But read what RioRico posted 15 minutes before you. All those lights in the display are there to give you a good feeling. Despite this, the camera is focusing on only one thing. It's a law of optics.
« Raw | SDHC cards »
camera, image, k-x, k-x with 18-55mm, lens, pentax, pentax help, photography
Pentax lack of scene mode splurf Troubleshooting and Beginner Help 52 11-30-2009 06:03 PM
Fine Sharpness in Custom Image on K200D MoiVous Pentax DSLR Discussion 9 08-03-2009 11:21 AM
Does ISO affect Image Sharpness? philbaum Pentax DSLR Discussion 2 06-16-2009 07:08 PM
Differing level of sharpness in the same image matiki Photographic Technique 12 07-03-2008 02:31 PM
For Sale - Sold: FS: Kit Lens DA 18-55mm, 52mm B+W filters and Image Doctor Software (budled or azcavalier Sold Items 0 10-25-2007 07:24 AM
All times are GMT -7. The time now is 07:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
