Originally posted by jct us101 Could you specify this focus issue, because my new Nikon D50 has the same problem, but every Pentax and Canon DSLR I've used can focus on multiple things at once. I'm assuming you mean because of the DOF rules, you can't focus on two different planes at once (since you don't have a tilt shift lens most likely)?
A lens
cannot be focused at multiple points. Assuming its image field is pretty flat, it can focus on just one point in one plane at a time. With a tilt-shift system, that plane can be at an angle; otherwise it's parallel to the sensor or film. (Curved-field lenses are something else, but you hopefully won't run into many of those now.)
A camera that SEEMS to focus at multiple points, is reading the distance to those points, then applying an algorithm involving those distances and the aperture, to try to get them all within DOF range. Maybe we need a sensor that marks those points, determines a plane they're all in (but no more than 3 of them), and physically orients itself (and the lens) to be parallel to that plane. Don't hold your breath.
