Originally posted by NRV Shooter I need some sort of 70-210/80-200 zoom for my ME Super as the Takumar A I have has terrible "zoom creep", with the zoom function so loose as to be annoying. I read nice reports about some of the Tamron zooms, particularly the 70-210 19AH, in that zoom range and thought I would investigate what all is needed to make them work. Obviously one needs a lens and an adapter.
I think I will lean more, as I did initially before starting down the Tamron road, toward a Pentax A 70-210 or an M80-200 as it will see more use on my ME Super than on the K10D which should be sporting a DA55-300 by the weekend.
Thanks again for the help and any further suggestions will be greatly appreciated.
The #19AH is a fine lens, perhaps better than the esteemed Vivitar Series 1 70~210/2.8~4 P/KA version 3. It can be had in Ex condition for around $100. The KA adapter is another $100.
My advice is if you invest in the KA adapter, plan to also invest in several of the better Tamron SP lenses that are rated near the best OEM lenses of the time, spreading the adapter cost over more than one lens.
The reasonably-priced (risking flames if I leave some out) are:
#52B 90/2.5 Macro
#06B 350mm Catadioptric Mirror (*** f/5.6!!)
#55B 500mm Catadioptric Mirror
(these two are the best moderately priced mirror lenses available. The Vivitar Sereis 1 solid-optic cats designed by Perkin Elmer are better, but the prices for those, when you can find one, are extreme).
#01A 35~80/2.8~3.8
#19AH 70~210 you are considering
The 1.4x and 2.0x teleconverters are also excellent.
There are some fine lenses in the earlier Adaptall-2 (pre-SP) category at very good prices - in the tens of dollars.
A few of the specialty lenses are quite rare and expensive - SP 180mm, SP 300mm, etc.
Read all the descriptions - they are generally accurate.
You can research them at
Adaptall-2.com
