04-07-2010, 06:25 AM   #1
K-7 Firmware updates
I have a K-7 that has firmware V1.00. I know that the latest update is 1.03, do I need to update V1.01 and 1.02 or does 1.03 include the two previous updates? Any help would be greatly appreciated
04-07-2010, 06:54 AM   #2
Parallax's Avatar
The latest update will always include any previous updates.
04-07-2010, 08:45 AM   #3
Thanks for the help Parallax...
Never forget how much you can learn from just listening.
04-20-2010, 04:32 AM   #4
be VERY careful with the update - (don't do it if you don't need to would be my advice) - I followed all recommendations to the letter re: having a fully charged battery before I start etc etc. The update process froze part-way through, leaving me with an unusable camera which needed a warranty return to base for a new main board installation. I was NOT a happy camper.
cheers
gm
04-20-2010, 05:08 AM   #5
Well, I always check the firmware copied on the SD card before running the upgrade, through a MD5 sum. This is quick, and ensure you have a working firmware update ready to go!
04-20-2010, 08:33 AM   #6
Make sure to do the firmware update though.
There are a number of issues with 1.0 that are well sorted out in higher versions, for instance:
- Green line issue
- Hot pixel issue
You can search for some old posts on these issues.
Also, you will get new functionality: an extra focus selection point option, more supported lenses for the in camera correction and more settings for image sharpness.
Of course these extras are not described in the original manual
- Bert
04-20-2010, 10:16 AM   #7
QuoteOriginally posted by geoffm Quote
cheers
gm
Given their policy, at least they fixed it. There must be something going on with a given batch of cameras that is causing the cameras to brick, even if you follow the instructions. The caveat is that they DO recommend you use the AC adapter to Insure you don't run out of power. How many people have bought Those? I also wonder if they will tell you to go pound sand and cough up the cash if you use one of these "Silent" updates that doesn't make it to all the sites.
QuoteOriginally posted by dlacouture Quote
I should probably know this, but how does one check the MD5 sum and how is it useful with respect to insuring a good FW file?
camera, firmware, k-7, k-7 firmware, pentax help, photography, updates
Firmware Updates slowpez Pentax DSLR Discussion 4 02-23-2010 04:41 PM
How many firmware updates for K-7? ronin67 Pentax DSLR Discussion 2 12-12-2009 07:29 AM
firmware updates? pixel r0n1n Video and Pentax HDSLRs 3 09-11-2009 11:27 AM
Firmware updates cupic Pentax DSLR Discussion 12 05-12-2008 07:58 PM
Firmware updates jimbrechin Pentax DSLR Discussion 11 08-08-2007 11:35 PM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
