View Poll Results: What is your preferred JPEG file size and quality settings? (2 choices max.)
14 Mp [****] 1751.52%
14 Mp [***] 515.15%
14 Mp [**]   00%
14 Mp[*]   00%
10 Mp [****] 721.21%
10 Mp [***] 13.03%
10 Mp [**]   00%
10 Mp[*]   00%
6 Mp [****] 515.15%
6 Mp [***] 39.09%
6 Mp [**]   00%
6 Mp[*] 13.03%
2 Mp [****]   00%
2 Mp [***]   00%
2 Mp [**]   00%
2 Mp[*]   00%
Other 39.09%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
04-09-2010, 12:58 PM   #16
QuoteOriginally posted by EsBee Quote
I am not sure if that equates to more speed from the camera body unless you are including write speed also.
I would have thought that all photos are captured in native format (RAW) first. If that assumption is true, a sinlge RAW photo should generally beat a single JPEG photo in overall speed from the camera body in most cases because of the overhead involved in compressing the RAW into JPEG.
Hi EsBee,
I don't quite get how write speed can be separated in any practical sense. I imagine that you might be correct theoretically, but I don't usually shoot theoretically, unless I include dreaming. . .and I've yet to discover how to use image files that haven't been saved to the card.
Scott
04-09-2010, 05:16 PM   #17
hcc
hcc's Avatar
QuoteOriginally posted by snostorm Quote
Hi EsBee,
Scott
The notion on 'write speed' is linked with two different issues:
- the post-processing done on-board by the camera processor, and
- the transfer speed from the camera memory buffer to the card.
Let me use two examples. When we use the camera lens distortion correction, the camera does some post-processing after each shot, and it takes ~1 s before the photo is saved on the SD card. This is linked with the on-board post-processing. There are other post-processing functions: some are very fast other as slower.
On the other hand, when we take a photograph, the file must be written on the SD card. There are different categories of SD cards that are related to the specified transfer rate: e.g., a class 10 card is specified for 30 Mb/s. The transfer rate is particularly important when you do some continuous shooting: the camera will slow down its burst rate when the buffer is full as a resut of a slow card transfer rate.
While the topic is not directly relevant to the original thread on JPEG image file size and quality settings, it is pertinent for some applications, incl. continuous shooting.
Hope that the comment may assist ... and that other Pentaxians wil share their experience and expertise.
04-09-2010, 07:58 PM   #18
Itai's Avatar
It is interesting that it would seem mose people prefer to lower resolution than quality which is the wrong way to go.
If you notice that stepping down in quality vs resolution (compared to the maximum of both) until the file size is roughly the same, the image will look better when resolution is higher because both are kinds of compression. Reducing resolution simply removes information uniformly everywhere while compressing removes information the least likely to be noticed (at least according to human visual system studies).
- Itai
Digital Camera Buying Guide, Photography Articles and Reviews | NeoCamera.com
04-10-2010, 08:44 AM   #19
JPEG sizes vary depend on the content of the photograph. For example, at any resolution the photograph of a flower with a clear blue sky as the background will be a lot smaller in size than of a typical landscape with various things in it such as lakes, mountains, trees and flowers, etc.
04-10-2010, 12:54 PM   #20
Marc Sabatella's Avatar
I shoot at the higest quality I can. If I wanted a worse camera, I'd have *bought* a worse camera.
04-10-2010, 08:35 PM   #21
Itai's Avatar
Well said
04-10-2010, 08:44 PM   #22
gramps50's Avatar
Like Marc I will normally shoot at the highest mp and best quailty the camera will do then if I need a smaller file size for some reason I will do it PP
camera, jpeg, mp, pentax help, photography, quality, size, vs
Image size Jacos Troubleshooting and Beginner Help 15 04-11-2010 02:47 PM
JPEG vs RAW image comparison FHPhotographer Digital Processing, Software, and Printing 64 02-12-2010 11:25 AM
K20d jpeg file size rustynail925 Pentax DSLR Discussion 8 09-05-2009 06:00 PM
PPL: JPEG quality vs compression vs size wasim_altaf Digital Processing, Software, and Printing 4 08-13-2009 03:13 PM
JPEG file size Mike Moffet Pentax Film SLR Discussion 4 10-28-2007 03:20 PM
All times are GMT -7. The time now is 06:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
