Originally posted by Naturenut To everyone. Thanks for all the great suggestions.
Right now we're talking a couple of hundred ($200) max US dollars for my budget. I'm interested in taking still life and floral close ups at this point. Does that help at all re: narrowing it down?
That's a fair sized budget to enter into macro photography. I recommend you go with a 90 to 100mm macro lenses that can reproduce up to either 1:2 or 1:1 images. Preferably with auto aperture setting to make your life a little bit easier. This will allow you to pursue the type of images you seem interested in.
I am sure there are many nay sayers, but I would not recommend reversing rings. This set-up is for extreme closeups, where you can get real close, more than 1:1. Depending on the lens used, your subject will literally be just millimeters away from the lens. Breathe too heavily or sudden movement can have you diligently blowing pollen out of the rear element of your lens. Worse yet, you may bump into the stamen of the flower with your reversed lens because you forget how close you are and you will end up trying to wipe the colourful and sticky residue from the lens (been there, done that). Plus, to compose and focus properly with reverse mounted lens (and to prevent the above from happening), you need very precise control of the x,y, and z axis. The equipments that will give you some degree of adjustment over the 3D planes, will quickly eat into your budget, even if the mount itself is so affordable.Try it if you must, but it would be far more satisfying to fully explore the near-macro to macro photography before trying extreme closeups.
