04-14-2010, 09:10 AM   #1
Batteries dying
Hey all!! I am new on here and new to photography. I recently bought a K-x, which is my first real camera. In the last month or so I have been going through batteries left and right. 4 AA batteries will only last me 20-30 shots for some reason. The only camera setting I thought would matter is the "auto power off" tab in the menu option., which is set for one minute. I am hoping it is something simple
04-14-2010, 09:19 AM   #2
Senior Moderator
Nass's Avatar
Hello, and welcome
Do you keep liveView on continuously?
04-14-2010, 09:22 AM   #3
It IS something simple.. What kind of AA batteries are you using? The generally accepted best type of Kx batteries (or any other DSLR running on AA) is Eneloops, with a Slow charger. If your current batteries are the 7-11 duracell coppertop types, you're getting good use out of them. If they Are Eneloops, then you have a different problem, either with the batteries, or the camera.
04-14-2010, 10:53 AM   #4
I bought my K-X about a month and a half ago and am still using the same batteries and have taken over 1000 shots easily.
Try using the energizer lithium 8x batteries. They work great.
04-14-2010, 10:59 AM   #5
GerryL's Avatar
Is the firmware the original 1.0 version?
If it is then, you have to update it since it fixes the K-xs battery issue problem wherein it doesn't read the charge of the battery right.
You might be using the wrong batteries too!
Have a read of this: https://www.pentaxforums.com/forums/pentax-dslr-discussion/92821-battery-k-x-...-take-aas.html
Hope this helps!
04-14-2010, 11:01 AM   #6
I would check the settings on the LCD that's the big power suck on my Pentax.
04-14-2010, 11:22 AM   #7
Nesster's Avatar
I was going to suggest the same sticky topic Gerry did.
What you need to do - go to the Pentax site and download new firmware, install that in your K-X and your battery problems are fixed. The instructions for doing this should be buried somewhere in the topic... if not, google is your friend. I did this to my daughter's K-X and it cured her problems.
04-14-2010, 03:28 PM   #8
GerryL's Avatar
QuoteOriginally posted by Nesster Quote
Hmm..I didn't know that your daughter had a problem that needed to be cured too apart from her K-x, having problems of its own..LOL
04-15-2010, 01:47 PM   #9
Nesster's Avatar
Yes, it was a remarkable recovery ... she got her camera to deal with the batteries, a scholarship & decided on college, and got a photo related senior study project approved. Who knew that a simple firmware update would do all that.
04-15-2010, 03:34 PM   #10
Thanks to everyone who replied!! Personally I never owned anything that did not work on straight alkaline batteries. So it was a simple fix!!
I currently do not have my owners manual with me so I appreciate the responses.
Thanks
Jason
batteries, camera, pentax help, photography
Professional photography dying? interested_observer Photographic Technique 33 04-27-2010 10:37 AM
Just dying to get my Pentax... miss.sara Welcomes and Introductions 6 06-27-2009 11:58 AM
The dying rose Jebus Post Your Photos! 7 05-27-2008 05:25 PM
Is LightZone dying? bc_the_path Digital Processing, Software, and Printing 3 05-16-2008 08:00 PM
Been dying to use my K10D... quickpix Post Your Photos! 2 01-17-2008 08:38 AM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, part of our network of photo forums!
