04-14-2010, 09:14 PM   #1
Clean Pentax SMC Lens
I was cleaning my pentax DA 55-300 mm lens (dust, finger prints) and I used compressed air in a can. I noticed it contained difluoroethane. Is this bad for the SMC coating?? Pentax suggests not to use alcohol and etc.
Also, how scratch resistant are these lenses?
Thanks
04-14-2010, 10:30 PM   #2
just a little advice, my photo professor said that you get a air canister and run it half way, halfway cause the elements in the compressed air get out. After you can clean your lens or image sensor with the rest of it.
04-14-2010, 10:48 PM   #3
AOShep's Avatar
QuoteOriginally posted by ptwist61 Quote
That makes a lot of sense. But how do you know when you are half way? If I can't feel any moisture when I spray, I consider it safe.
04-14-2010, 10:53 PM   #4
Wheatfield's Avatar
I've been using canned gas for general cleaning for about 4 decades without damaging anything (other than the environment, but that wasn't deliberate).
You can butt a cigarette on an SMC lens without hurting it, the coatings are pretty tough.
I suspect methanol might not be the best thing to use as a lens cleaner, especially when just breathing on the lens is generally enough.
04-14-2010, 11:42 PM   #5
wlachan's Avatar
I use isopropyl alcohol and acetone on all my SMC lenses and HOYA filters w/o ill effect. In fact, a Zeiss doc that I found somewhere said they were safe for lens cleaning too. The now discontinued UK product called Opti-clean contained acetone also. I have never used canned air however since nothing my rubber blower can't do for my need.
04-14-2010, 11:46 PM   #6
QuoteOriginally posted by wlachan Quote
I use pure acetone too, and if you keep it away from plastic and painted surfaces, it's very good at cleaning lenses. It was suggested to me by a manufacturer of optical components used in laser applications, when I bought a beamsplitter mirror from them to repair an old rangefinder camera.
04-15-2010, 01:45 AM   #7
Pentaxie's Avatar
Yes, alcohol is good for cleaning lenses.
I heard that the SMC lens coating is quite tough. A little alcohol wll not hurt it, the coatings are pretty tough. As a forum member mentioned earlier "methanol might not be the best thing to use as a lens cleaner", but IMO it should not posed a problem.
The method of cleaning lens that I used is still the old trusty way, breathing on the lens and wipe off with a clean micro-fibre cloth is generally enough.
Cheers.
04-17-2010, 05:01 AM   #8
Thanks
Hey, just wanted to thank everyone for their input! It seems that people clean lenses a million different ways.
04-17-2010, 05:46 PM   #9
Tuner571's Avatar
Yes, I use alcohol to clean my SMC-A lenses and have never had a problem with any kind of coating problem. I think that as long as you are very careful there is nothing to worry about when cleaning you lenses, just take your time and be gently.
camera, lens, pentax, pentax help, pentax smc, photography, smc
For Sale - Sold: Pentax SMC K 55mm f1.8 very clean tvfd911 Sold Items 2 11-24-2009 02:00 PM
How do you clean your lens? gkopeliadis Pentax SLR Lens Discussion 42 06-17-2008 05:07 PM
SMC coating. How to clean Pentax lenses? Edvinas Pentax SLR Lens Discussion 7 10-27-2007 04:44 AM
what do you use to clean your lens? slip Pentax Film SLR Discussion 17 05-25-2007 01:07 PM
How do you clean up an old lens Alvin Pentax SLR Lens Discussion 3 02-19-2007 08:06 PM
All times are GMT -7. The time now is 11:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
