04-16-2010, 09:48 AM   #1
Auto focus grind
Lens is less than six months old, was out today just messing around and then this happened
[YT]http://www.youtube.com/watch?v=bwsvYwZpbLs[/YT]
04-16-2010, 01:34 PM   #2
I've heard people complain about noisy AF with the screw drive lenses but that sounds ridiculous . Is it actually Focusing and is it only with That lens? Does it happen at All zoom ranges (I notice you racked it all the way out). Something is broken it sounds like, or is about to break. If new, I'd send it back for replacement.
Edit, just re-read.. Warranty repair trip sounds like it is needed.
04-16-2010, 01:39 PM   #3
It was not focusing at all. I changed lenses and at first it did the same thing. but i cycled through the focus modes and then it stopped. both lenses focus normally now, but it was weird cause just a minute earlier it was autofocusing just fine.
04-16-2010, 01:44 PM   #4
QuoteOriginally posted by rattrap Quote
If it did it with a second lens then it's the camera. Look for metal shavings around the lens mount. Something isn't right. Either the AF is not completely engaging or something is jamming it from turning (internal to the camera)..
04-16-2010, 01:49 PM   #5
just looked, no shavings of any kind and nothing looks stripped or broken.
I can't replicate the problem anymore
04-16-2010, 01:52 PM   #6
I'd definitely keep a close eye on things and send the camera in if it happens again.
04-16-2010, 01:54 PM   #7
thanks, I really appreciate the help
04-16-2010, 04:20 PM   #8
That noise is frightening. It should still be covered by warranty, I would send it in for checking before any further use.
04-17-2010, 05:50 PM   #9
Tuner571's Avatar
Wow, that really does not sound good at all. As another member said it sounds like the gears are slipping or something. If I were you I would not wait and see what happens, I would send it in now along with the video you took so that they might be able to fix the problem.
04-17-2010, 07:41 PM   #10
the only thing is I haven't been able to replicate the sound, and this might just be wishful thinking, but i think it was just a temporary problem.
I don't quite know what the problem was, but she focuses fine now
04-19-2010, 02:19 AM   #11
Pentaxie's Avatar
Wow! Such loud noise (literally speaking)!
IMO, it may be due to a new lens which has not been "seasoned" as yet. After some time of usage, I believe the noise will be gone. as the lens mechanism feels smoother in your hand.
Cheers.
04-19-2010, 03:35 AM   #12
QuoteOriginally posted by Pentaxie Quote
Cheers.
You're Kidding, Right? No New lens or camera, especially one from Pentax, should make that noise.
04-21-2010, 01:59 PM   #13
QuoteOriginally posted by JeffJS Quote
Seconded.
It sounded as if the "screw drive" had not engaged properly.
Inspect it for dammage and debris.
auto focus, camera, pentax help, photography
Auto focus: which is better K7 or K-X? gfmucci Pentax DSLR Discussion 18 07-17-2010 10:15 AM
Uh oh! Auto focus... NecroticSoldier Troubleshooting and Beginner Help 5 03-08-2010 06:21 PM
Auto-focus doesn't auto anymore jonhock Pentax SLR Lens Discussion 4 11-26-2009 11:28 AM
IS there Auto Focus assist in Auto with the Metz 58? madman6767 Pentax DSLR Discussion 5 01-26-2009 06:27 AM
Auto focus seems slow, off focus after repair voicelit Pentax DSLR Discussion 0 10-14-2008 11:15 PM
All times are GMT -7. The time now is 09:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
