04-23-2010, 08:22 PM   #16
Marc Sabatella's Avatar
There's no difference in how the aperture blades behave when using the ring or not - either way, the lens stays wide open until you press the shutter. But on some lenses, using the aperture ring hastens the eventual breakdown of the ring itself, so that would be abnother reaosn to avoid the ring. But mostly it's as said above - using the aperture ring is fine if you don't mind losing all automation, but since you *also* lose your meter, it's limiting yourself unnecessarily. You can shoot in manual mode in A position if it please you to shoot manually, but at least you still get a meter when the lens is on "A".
To borrow your analogy to the stereos, moving the needle on the turntable yourseff is fine if it pleases you, but not a great idea if it also limits the functionality of the system in other ways (say, disabling the volume control or EQ). And that's basically the case with using the aperture ring.
aperture, camera, change, pentax help, photography
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
K10d - Aperture Number error- JPEG/RAW najo Pentax DSLR Discussion 2 03-27-2009 03:52 PM
Feel stupid.... Aperture error. ViS Photographic Technique 9 11-17-2008 10:27 AM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
Can the Aperture ring? kshapero Pentax SLR Lens Discussion 5 10-28-2007 06:25 AM
All times are GMT -7. The time now is 08:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
