04-21-2010, 10:16 AM   #1
Focusing screen removal
I posted a while back that had a spot in my viewfinder, well yesterday when I had the lens off I found it on the focusing screen. So I was just wondering if it is easy to remove it, but how much of a risk do I take in getting more crud in while i have it out?
04-21-2010, 10:26 AM   #2
Is this just a piece of pollen or dust on the screen? Or are you talking about removing the screen altogether. Can't imagine why anyone would want to remove the screen. Look up Copperhill Method on the Internet and try this first.
04-21-2010, 10:35 AM   #3
Just1MoreDave's Avatar
On the high-end Pentax DSLRs, the focus screen is designed to be interchangeable. It comes right out. On lower end models, it's possible but more work. However, the screens are somewhat fragile. It's hard to get it completely clean and back in without making it worse or possibly damaging it. A lot of cleaning chemicals will melt the screen. I leave mine in place and use a blower for dust.
04-21-2010, 10:47 AM   #4
Pauld's Avatar
You can also take a dust blower and spray it into the chamber and try to dislodge if it's just a piece of dust. Without knowing what type of camera you're using it's tough to give sound advice. If it is a newer DSLR it's pretty simple to take out your focusing screen and either replace it or clean it.
04-21-2010, 11:05 AM   #5
I had dust on the focusing screen and decided to take it out and blow it off. It worked, but the dust returns. Every time you take out the screen you run a risk of scratching it or getting even more dust onto it. I've since stopped worrying about the dust on focusing screens since it doesn't affect my pictures. I would advise that you also leave it alone unless it is affecting your metering.
bb
04-21-2010, 11:21 AM   #6
it's a K20, but as far as what it is i do not know. I already tired to just blow it off but it looks like its on the other side of it.
04-21-2010, 12:45 PM   #7
imtheguy's Avatar
I don't have a link handy but there are a number of youtube vids showing removal/replacement of the focusing screen. Once you realize its just one clip holding it in and do it, the next time will take 20 seconds. Plastic tweezers or metal ones with some soft tape around the tips are needed to safely handle it if you are actually taking it out versus just blowing off the top while its unclipped.
04-21-2010, 06:37 PM   #8
In addition to all of the above, once you remove the screen, you have exposed the bottom of the prism to dust. Dust is often static charged and will attract to exactly the place you don't want it.
camera, pentax help, photography, screen
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
K-m focus screen removal bigtench Pentax DSLR Discussion 5 08-15-2009 08:00 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
For Sale - Sold: K100d and 18-55mm kit lens + split focusing screen installed + glass screen pr vanchaz2002 Sold Items 1 07-24-2008 07:09 AM
All times are GMT -7. The time now is 12:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
