04-22-2010, 07:45 AM   #1
Dust on Sensor
I'm sure this has been addressed multiple times--but--would any of you have some tips&tricks on clening the sensor--I have a K100D-and a istD--and it seems that when switching between lenses multiple times there is always a speck or two of dust that migrate to the sensor....
04-22-2010, 09:50 AM   #2
SpecialK's Avatar
1. Turn off camera when changing lenses. The electricity going through the electronics attracts dust. This was the biggest help I found.
2. Remove the lens, then use the sensor cleaning function to flip the mirror up. Blast a half dozen blasts into mirror area (don't put blower inside the mount, though). Use a rocket blower with a big, repeat, big, bulb that can move a lot of air. The little 1-inch type that come with cleaning solution and tissue paper are not large enough.
3. Turn off the camera to drop the mirror.
4. Check the rear of the lens, then reattach it.
5. Shoot a blank white or gray wall at the smallest aperture you can (f 8 or f11 etc), and examine the shot for dust.
6. Repeat 2-5 as needed.
04-22-2010, 10:17 AM   #3
I would add a step to SpecialK procedure, between step 1 & 2, that is to use blower BEFORE going into sensor cleaning mode with mirror lockup, to blow dust from mirror box first.
First time may require 10 or more repeats of all steps. Once clean, yes, do turn off camera when changing lenses, then change quickly, with opening pointed downward.
04-22-2010, 05:54 PM   #4
Wheatfield's Avatar
This always makes people cringe, but I use canned gas for routine sensor cleaning.
It seems to work.
04-23-2010, 01:09 PM   #5
Tuner571's Avatar
This is pretty much it, however one important tip is to make sure that the camera is pointed down when changing lenses. That way you decrease the chances of something flying in. This tip also works when you are cleaning the sensor of dust with a blower. Anything that comes off the sensor simple falls out of the camera.
04-23-2010, 04:07 PM   #6
rparmar's Avatar
As I have said in previous threads, I use an Arctic Butterly, an electrostatic brush that is compact and goes anywhere. Running this across the sensor a couple times works for me, though I only need to do so once every four or six months... and I change lenses all the time.
Buy the cheapest one available and read the directions.
P.S. Love Pentax dust reduction system!
04-27-2010, 03:58 PM   #7
I use a "Digital Survival KIT". I'd only recommend this if your sensor is very dirty and a blower doesn't get all the dust out.
camera, dust, pentax help, photography
dust on sensor or dust on lens 41ants Troubleshooting and Beginner Help 10 10-08-2009 10:28 AM
Sensor Dust or what??? NT-Tim Pentax DSLR Discussion 10 03-25-2009 08:01 PM
dust on sensor Christl Troubleshooting and Beginner Help 4 03-14-2009 03:06 PM
sensor dust(?), again tibbitts Pentax DSLR Discussion 1 10-02-2008 04:12 PM
dust behind sensor? jsundin Pentax DSLR Discussion 3 11-24-2006 09:51 AM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
