04-23-2010, 11:33 PM   #1
using the exposure compensation
when to use the exposure compensation
Last edited by tinabalagosa; 04-23-2010 at 11:35 PM. Reason: was looking for the same threads, did the wrong turn
04-24-2010, 02:47 AM   #2
Hi Tinabalagosa,
When your camera meters a scene, the meter may well be overly influenced by a large dark or large light area. Remember that the camera sets itself to give an average tone over the whole image, this for example would mean that a snow scene would be exposed as an average grey color and a lump of black coal would also be exposed as average grey. To compensate for these situations, the exposure compenstaion control allows you to set the camera to under/over expose so that the finished picture looks the same as your eyes see it.
Hope this helps, Richard.
04-24-2010, 03:07 AM   #3
Ash
Community Manager
Ash's Avatar
You may also find some valuable insight on exposure compensation and related topics discussed in this article: https://www.pentaxforums.com/forums/photography-articles/23232-learning-basic...echniques.html
04-24-2010, 03:32 AM   #4
AOShep's Avatar
I find it easier to switch to manual mode. Then I can quickly over or under expose by as many stops as I feel necessary. Turning the histogram on also helps a lot.
04-24-2010, 07:07 PM   #5
Marc Sabatella's Avatar
The short answer: exposure compensation makes your pictures brighter (positive numbers) or darker (negative numbers). So you use it if you brighter or darker pictures than you get without it. Most pictures should be fine without it, but when you see you've taken a picture that's too dark, then use compensation to brighten up the next one. if you read up on exposure as suggested above, you can learn to anticiapte when you'll need compensation even before taking the shot (eg, any scene that is backlit or brighter than average will require positive compensation).
04-25-2010, 01:55 PM   #6
Hi
Simple answer: when needed.
Personaly: taking photos of people agains strong back light...
I do positive compensation when I need to have detail about the persons themselves.
Best regards,
camera, compensation, exposure, pentax help, photography
Exposure Compensation BookSaw Photographic Technique 12 01-06-2010 09:35 AM
What is exposure compensation doing? Javaslinger Troubleshooting and Beginner Help 16 12-11-2009 09:38 PM
Your Exposure Compensation lurchlarson Photographic Technique 21 07-18-2009 05:42 AM
exposure compensation basket-balls101 Troubleshooting and Beginner Help 12 05-11-2009 10:52 PM
exposure compensation... DanLoc78 Pentax DSLR Discussion 3 10-08-2008 01:19 PM
All times are GMT -7. The time now is 04:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
