04-24-2010, 09:06 PM   #1
Focus Ring?
Can someone explain why they did away with the Tak focusing rings?
04-24-2010, 09:36 PM   #2
KungPOW's Avatar
Autofocus.
04-24-2010, 09:38 PM   #3
Did away with? Do you mean changed the Style? Construction materials, more lightweight for Autofocus (when they actually started making AF lense), those nice feeling rubberized grip type rings that originally replaced the Tak focus rings on the K lenses... Probably several others but those would be a start.
04-25-2010, 02:12 AM   #4
From experience. kit lens still has focus ring, DA55-300 still has it and FA31 has it. Not sure what you're talking about?
Ain't you confused with aperture ring?
04-25-2010, 08:47 AM   #5
QuoteOriginally posted by JeffJS Quote
Uhh, yeah I meant the style where it had like... the curved stuff on the focusing ring. ;((( like on the M and A lenses they had a different focusing...
04-26-2010, 10:59 AM   #6
Just1MoreDave's Avatar
I'm not a manufacturing process expert, but the old metal rings have many machining steps. Replacing those steps with essentially a rubber band is a lot quicker. They can start with less metal because they aren't machining a lot of it away.
You might think the resulting lenses are lighter, but that's not always true. The Super-Multi-Coated Takumar 135mm f2.5 is optically identical to the SMC Pentax 135mm f2.5, but somehow the Pentax version gained weight. I think it's 15 grams heavier but I'm too lazy to look it up.
04-26-2010, 12:50 PM   #7
Lowell Goudge's Avatar
I suspect it is two fold.
I am sure someone in marketing told engineering that they wanted rubber grips, for look feel etc...
and I am also sure that from an inventory point of view, the extrusions for each diameter lens were a pain in the butt and it was simpler to machine the parts to what ever diameter they wanted, but it would need rubber grips not the extruded collars they had in the past.
DA* 50-135mm Focus ring GLXLR Pentax SLR Lens Discussion 16 01-10-2018 02:32 PM
Stiff Focus Ring geauxpez Pentax SLR Lens Discussion 6 04-12-2010 09:34 AM
Focus ring M & A Recercare Pentax SLR Lens Discussion 11 09-12-2009 07:47 AM
What the.... ?! New FA 50, focus ring jiggle. Ratmagiclady Pentax SLR Lens Discussion 20 12-15-2008 06:53 PM
how is your Sigma 10-20 focus ring? Gooshin Pentax SLR Lens Discussion 4 03-28-2008 10:57 AM
All times are GMT -7. The time now is 01:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
