04-30-2010, 07:30 PM   #1
How do I know if pentax cameras can share lenses?
I have a pentax k-x and wanted to buy a k10d or k100d, maybe a different pentax. How do i know if I can share lenses between the two cameras? I am guessing it would be more trickier with af lenses but still not sure.
04-30-2010, 07:49 PM   #2
Ole
Ole's Avatar
You can share lenses. All Pentax DSLR cameras take the same lenses.
The only catch is that the K100D cannot autofocus with the two SDM-only lenses - the DA 17-70mm and the DA* 55mm. The K100D Super can.
The K10D needs firmware 1.30 or higher in order to work with the two lenses mentioned.
04-30-2010, 07:52 PM   #3
noblepa's Avatar
QuoteOriginally posted by justtakingpics Quote
Unlike Nikon and Canon, all Pentax lenses will work on all Pentax cameras, with full functionality.
As long as we limit the discussion to dslrs, the only exception is that a couple of the new lenses are HSM (in lens focus motor) only and will not work on older Pentax dslrs, which only have screw-drive, in-body focus motors. I believe that any Pentax dslr from the K100D Super or newer will support HSM lenses.
So, as far as I know, any lens that works on your K-X will work on a K10D (with firmware version 1.30). The K100D can not support HSM lenses, but otherwise would share all lenses with a K-x. A K100D Super CAN support HSM.
Anything newer than that, including the K200D, K2000/K-m, K10D, K20D and K7 can share all lenses with the K-x.
Backwards compatibility is one of Pentax's selling points. Not only will all current lenses work on all current dslrs, any k-mount lens will work on Pentax dslrs. Even screw-mount Pentax lenses work (with an adapter) on Pentax dslrs. I use a 50mm, f/1.4 Super Takumar from 1967 on my K10D and love it.
04-30-2010, 09:37 PM   #4
Wheatfield's Avatar
If it works one one Pentax, odds are it will work on all of them
camera, cameras, lenses, pentax, pentax cameras, pentax help, photography, share
Full Range of Pentax D-SLR Cameras and Lenses (UK) jeffski Pentax DSLR Discussion 2 11-18-2009 04:44 PM
Third Party Lenses stuck on Pentax Cameras Damn Brit Pentax Lens Articles 3 07-23-2009 10:38 AM
Photos of new Pentax cameras and lenses at PIE 2008 jeff1101 Pentax News and Rumors 4 03-31-2008 02:21 PM
Long Lenses for Pentax Cameras Rick Woodward Pentax DSLR Discussion 9 02-19-2008 07:18 AM
Pentax Screw-mount Cameras & Lenses Matthew Roberts Pentax Film SLR Discussion 7 04-21-2007 02:53 AM
All times are GMT -7. The time now is 10:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
