05-02-2010, 10:57 AM   #1
Thin Blue Line in Pictures
Can someone give an opinion on what is causing this? (see image - taken without lens)
05-02-2010, 11:20 AM   #2
What camera and what firmware are you using? The reason I ask is that when first released there was an issue with a thin Green line in photos. A firmware release did address it and clean it up.. What happens when you put a lens on the camera?
05-03-2010, 03:55 AM   #3
The line is in my photos as well - I just tried it without the lens (and a new memory card) to narrow down the problem.
It's a K20D (about one year old) and not sure what firmware...
05-03-2010, 03:58 AM   #4
blende8's Avatar
Looks like a sensor defect.
05-03-2010, 07:55 AM   #5
QuoteOriginally posted by jbuttonphoto Quote
I shouldn't type on the fly. It was the K7 I was talking about. Never heard of such an issue with the K20d.
Good luck with it.
05-03-2010, 02:44 PM   #6
Thanks Jeff - I downloaded the newest firmware however the line is still there...guess I'll have to see if I can get it covered under warranty (it's just at the one year mark now). Thanks!
05-03-2010, 05:02 PM   #7
For the photos you already have with the issue, you might want to try Pixel Fixer | Hot pixel removal utility . For your issue, you might try the pixel mapping option in the camera. As the Pixel Fixer web page notes, the lines can sometimes be cuased just by a single pixel.
Thank you
Russell
camera, dslr, photography
Pictures from Kx seem to be too blue (needs color correction) iamthehub Pentax DSLR Discussion 18 04-08-2010 03:44 AM
A couple Blue Heron and night pictures. jbrowning Post Your Photos! 0 11-08-2008 10:47 PM
March 2008 Third Place: Walking the thin line beest Winners' Showcase 0 03-03-2008 05:04 PM
Thin filters really necessary? Pentastic! Pentax SLR Lens Discussion 3 12-01-2007 09:28 AM
Whats the blue line around objects? reknelb Pentax SLR Lens Discussion 9 02-20-2007 07:50 PM
All times are GMT -7. The time now is 03:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
