Originally posted by SpecialK I'd probably just run some low-pressure warm water on it for a few seconds, then dry it carefully.
I'm a little concerned about doing that, because I don't know just how good the weather sealing is on the viewfinder to inside. I've had a film camera get wet on the outside viewfinder and some seeped in, the focusing screen was never the same after that.
Originally posted by Steve Beswick Q-tips might be more effective.
Yeah, I did end up using some q-tips last night, they did help a bit more. But I really don't like the way they leave behind little tiny fibers.
Right now there is still a quite a bit of a pepsi smear visible, as well as some fibers that got stuck. When I press my eye right up against the viewfinder all of this is pretty much invisible, but looking through it about 1/2 inch to an inch away I can see all of it quite clearly, and it is rather distracting.
I'm a little worried about putting too much force with a q-tip or other cleaning implement, because that seems like it could scratch the viewfinder glass. I'm trying to take a picture with my P&S camera, but it's hard to get a clear picture to show you guys.
I might consider using a tiny bit of detergent next, but I'm worried about being able to adequately wash that off. I'd like some input if I can safely run low pressure water over the viewfinder without any getting inside the camera and fogging the focusing screen.
thanks
