To "jeffkrol"
Thanks for the useful link, although I'm afraid most of this technical stuff is really a bit beyond me at the moment. I'm probably not supposed to do this, but I've 'borrowed' two extracts from that link, which appear to encapsulate one possible solution:
Quote: If you run your K10D DNG files through Adobe DNG Converter 3.6 before opening in Rawshooter, the colour problem does not happen. There's a link to the Adobe DNG Converter download next to the link for the modified .exe download.
Yes, on the face of it you are converting from DNG to DNG which looks like no change, but it fixes the colour problem.
AND
Quote: The DNG reader for RSE/RSP was written in too restricted a fashion to only handle the formats as output by the Adobe Convertor and did not handle the ***full*** specification including packed byte compression as used by the Pentax K10D.
The strange bytes on the one edge are the Totally Weird Photosites (TWP, a technical term ;-) that are in the raw data for 36 columns and are present in the processed RSE/RSP images because they do not handle the recommended crop area tags or the Active Area tags in DNG.
I haven't the faintest idea what 'packed byte compression' is, but could
this be the root problem in explaining why so many editing packages seem unable to 'edit' the RAW files produced by the K10D ??? Over to those more knowledgeable than I to comment on this info ???
