Originally posted by hockmasm is there a trick I am missing? I never know what shutter and aperture to start at.
For example, if i want shallow DOF, i know use f5.6, but I don't know which shutter! My backgrounds blown out and i keep rolling the dial and taking a sample shot until it looks right. sometimes 5 shots!
is there a trick I am missing to get close to what I need instead of winging it?? like can i put it on P mode, check its stats, then start from there????
The first question is, which exposure mode do you need or want to use?
If you have a K10D/K20D or K-7 with hyperprogram (P), then things are relatively easy. Use P mode. From there you can switch to effective Av or effective Tv simply by moving either the rear or front e-dial, respectively. If you don't like P mode for some reason, or don't have one of those cameras, then you have to decide on Av, Tv or M mode.
Choosing between Av and Tv is pretty simple. If you want to set the shutter (say, because you are shooting sports), and let the camera figure out the aperture, use Tv. If you want to set the aperture (say, to control depth of field), then use Av.
Of course if you use P, Av or Tv, you may also need to think about exposure compensation using the +/- button. If the scene is brightly backlit, or you're shooting snow or something like that, you might need to dial in +1 EC or something like that.
If you prefer to use M mode, things work basically the same way. You set whichever parameter you care more about first (shutter or aperture), then move the e-dial for the other parameter until the meter is where you like. Meter mark doesn't have to end up dead in the center in M mode! If you are shooting snow in M, instead of dialing in EC, you let the meter indicate an exposure of +1 (or whatever works). It's just a different way of thinking about things.
You said, if you want shallow depth of field, you use f/5.6. I'm curious what you're thinking about. If you want the shallowest depth of field possible, you can do at least two things:
- Use the widest aperture your lens has for your selected focal length. If you can go to f/3.5 or even better f/2.8, do so.
- Either zoom in on the subject and/or move closer. For a given distance between camera and focal plane and a given aperture, the longer focal length will have less depth of field. For a given focal length and aperture, being closer to the focal plane will give you less depth of field. So, if you want to blur your background, GET CLOSER, either by moving closer and/or by zooming in tighter.
My guess is that more photographers use Av than Tv, at least outside of the world of sports photography. Unless you're shooting sports, it's a good idea to learn how to control depth of field, and you can do that by shooting in Av—or by shooting in M and setting your aperture first. If you want to learn how to calculate exact depth of field values, you can consult an online app like this one:
Online Depth of Field Calculator
I have a depth of field app on my cell phone that I use if I really need precise info, which isn't all that often.
Will
