Jlaubza, I'm glad to hear you were able to clear up your own image-blur issues. However, do not let your experience lead you to believe that
all cases of K-x image-blurring are user-based.
In my case, I am quite experienced in the matter of getting sharp handheld images out of cameras with NO SR in the first place. I know what conditions I can handhold in and what situations I can't.
This doesn't change the fact that within a very specific shutter-speed range (1/100th-1/160th) my K-x produces slightly shaken images (doubling is evident), at any focal length, in any orientation, and
only when SR is
on . I get sharper images at
slower shutter speeds in many cases. My solution is simply to avoid those shutter speeds or turn SR off.
I can't help but feel that your tripod solution is a bit moot... if you can bother with a tripod, why do you need SR at all?
Personally, I always use the timer when shooting on tripod, so SR is disabled anyway.
I'm really not sure why threads like this keep popping up. It's been established that a small percentage of K-x owners experience consistent, minor problems that appear to be related to the SR or shutter mechanism (different users may in fact be experiencing different problems). These problems are not actually common, and a lot of complainers are in fact suffering from user error. I thought we had established all this and gotten over it already.
:P
