05-13-2010, 10:05 PM   #16
Thanks for the help! I will use these tips this weekend.
05-14-2010, 02:57 AM   #17
QuoteOriginally posted by RBellavance Quote
But keep in mind the histograms are based on the JPG, and this influenced by the white-balance. So even if you shoot RAW, it is a good idea to properly setup WB in-camera if you can.
I always thought you should leave the wb at 5000k (don't remember the exact temperature) to avoid reading the histogram for the corrected jpg. If you want a histogram that matches the rawfile then the jpg should be a straight conversion from the rawfile with as little corrections as possible.
05-14-2010, 09:12 PM   #18
White balance target
I use a WB target that has Black, white and gray on one side to set your exposure. The other side is solid white to set the White balance. Since I started using this, my colors look great (including reds). With flowers this type of target works well because they are not moving into different light. It helps if the color is correct when the exposure is made and you do minimal adjustments in the computer. There are several WB targets on the market including the kind you use like a lens cap.
Find what works best for you but I recommend getting it right in the camera first. I use my target with portraits every time and the color comes out great now. You have to remember when working outside to take another reading if you move. Light color changes just a few feet away. If you go from sun to shade or near an object that is reflecting color. I use custom white balance most of the time when I sell my work. The only time I use auto is for snapshots.
I have heard the K-7 and K-x has the most accurate auto WB around. I don't own one yet but maybe when I do, I can leave my target home.
Hope this helps.
05-15-2010, 05:30 AM   #19
audiobomber's Avatar
QuoteOriginally posted by psdigital Quote
You'll probably still want that target. I find the K-x AWB goes too blue in direct sunlight, Manual or Daylight setting is more accurate. With incandescen lighting AWB is close but a bit warm. I find the warmth can add to the mood of the photo, so it's also a matter of taste.
camera, canon, dslr, image, image quality, iq, k-7, page, photography, popphoto.com, quality, question about image
Image quality question and be nice pakuchn Pentax DSLR Discussion 52 01-25-2010 11:56 AM
How can I get good image quality from a K-x?? Manfred Troubleshooting and Beginner Help 38 12-20-2009 08:18 PM
K10d image quality question/issue vagabond79 Troubleshooting and Beginner Help 7 11-12-2009 12:29 PM
Basic question regarding image circle and edge quality tigershoot Pentax SLR Lens Discussion 3 01-27-2009 02:56 PM
Question about printing and image quality. triplej96 Pentax DSLR Discussion 11 11-18-2007 09:09 PM
All times are GMT -7. The time now is 03:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
