Quote: huh? Flashes don't have shutters.
I said it for the sake of the discussion since in limited light, the "flash duration" mimics the shutter speed
Quote: A little experiment is in order--I'm going to take several shots of a fan spinning at 1725 rpm with stickers on the blades and compare the onboard K20d flash with the Vivitar 285HV at different power levels.If all goes well I will have them posted in a few hours--charliezap
The flash duration is always going to change based on available light, aperture, ISO, pre flash (with non A lenses the flash is more powerful than with A lenses), whether red eye reduction is on/off etc.
One experiment you could do with the spinning fan is taking a series of images without flash, and checking at which shutter speed the fan looks static.
Then duplicate it with the onboard flash in a dark area to get a ballpark idea of the onboard flash duration.
