05-14-2010, 07:29 PM   #1
HELP! K100D Super with jammed MF lens
Hello out there, I just purchased a K100D Super at the Henry's Digital Imaging show and the first thing I did was pop on my 28mm lens (from my Ricoh gear, make is actually Magnicon), and it wont come off! Something inside is stuck, because it releases but only turns about 5 degrees and stops stiff, really stiff, like wrenching on it does not do anything stiff. If anyone out there knows my pain please post! I'd rather not wait 4-6 weeks for the warranty repair, I just want to use my camera!
05-14-2010, 07:41 PM   #2
Do a quick serach for "Ricoh" and "Pin" here on the forums. Your lens more than likely has a pin on it that is stuck in the AF screw drive hole. A few people here have been able to get a lens unstuck so searching out those threads should help.
05-14-2010, 07:43 PM   #3
Nowhere Matt's Avatar
First put down the camera before you really damage something. Now do a search for Ricoh lens pin sticking either here or around the Internet.
There are some manual focus lenses that have a pin that will catch on digital bodies. Do a search and read dome suggesting and cross your fingers. I wish you good luck.
05-14-2010, 10:25 PM   #4
yeah its got the pin. Im going to search for that stuff now.
05-14-2010, 11:42 PM   #5
a 0.20 mm automotive feeler gauge, poked it in behind the pin (behind from the frame of reference in the direction of rotation to remove the lens) and she popped right off.death to the pin!
05-15-2010, 12:16 AM   #6
Certainly better than death to the camera I say.
People get rid of those pins intentionally, so they can use their Ricoh gear safely.
05-15-2010, 07:29 AM   #7
sterretje's Avatar
Congrats. I don't think that this would have been a warranty repair so you have saved yourself some money.
05-15-2010, 09:21 AM   #8
I think there is currently a Sears 28mm f2.8 up for sale in the marketplace.
I'm sure many of us are relieved this one worked out as well as it did.
05-22-2010, 02:57 PM   #9
QuoteOriginally posted by jimi Quote
I found that an old 35mm negative strip was thin enough to slip into the gap between lens and body and stiff enough to depress the stuck pin. Slipping it into the pin area (near the autofocus switch on my k-m) and working it around until I got it under the pin allowed quick removal of the lens.
The advantage there is that the negative is far softer than the metal on the lens and camera mounts so there is no scratching on either camera or lens.
05-22-2010, 10:33 PM   #10
Blue's Avatar
QuoteOriginally posted by brycec Quote
The trick is to use a thin enough feeler gauge which are actually designed to measure without damaging precision metallic mating surfaces.
05-22-2010, 10:36 PM   #11
Blue's Avatar
I'm glad you found the feeler gauge solution!
05-24-2010, 01:17 PM   #12
Do not forget to remove the Ricoh pinafter your were able to dismount the lens. So next time will not be a problem.
05-25-2010, 08:28 AM   #13
GerryL's Avatar
If you have a Ricoh gear then you will be busy removing pins..that is still good though coz once that's done, you can use all those lenses on your new Pentax gear.
camera, dslr, k100d, lens, photography
Lens jammed on K200D hoonslim Troubleshooting and Beginner Help 5 10-16-2009 09:52 AM
Help: can't get lens to mount on new K100D Super Snicky Pentax SLR Lens Discussion 5 07-17-2009 08:03 PM
Mirror jammed up - Super A / Super Program pasipasi Pentax Film SLR Discussion 13 08-20-2008 12:56 AM
Best Pentax lens from a K100D Super? weirdnjfan1 Pentax DSLR Discussion 8 04-14-2008 12:30 AM
Getting K100D super, which lens hungup Pentax SLR Lens Discussion 2 11-28-2007 10:17 AM
All times are GMT -7. The time now is 01:34 PM. | See also: NikonForums.com, part of our network of photo forums!
