05-15-2010, 09:43 AM   #1
hockmasm's Avatar
Why does k-x "glow" my flowers???
Not sure why this is happening. but the inside of this flower is "glowing".
is it because of slight out of focus? other flowers come out the same too.
I have kit lens 18-55mm,'
05-15-2010, 10:17 AM   #2
Have you noticed the leaves at the lower part of the image ? That was where the camera focused on instead inside of the flower .
Your Kx might be on Multi Points Focus (Auto) and picked up the leave to focus on it . Set your camera to Center Focus Point (Spot) then you won't have this problem again .
05-15-2010, 10:35 AM   #3
You might also want to stop down the aperture some, so that you get a deeper depth of field, so that the entire flower may be well defined and in focus. It all depends on what you want to do. It looks like the lens is somewhat or near wide open, so the DOF is very shallow. By varying the aperture, it appears with the kit lens, you can have just the center of the flower in focus, or up to the entire flower. It might be worth taking a series of images at each f stop, so that you can see more and more of the flower in sharp focus. Just a thought.
05-15-2010, 10:36 AM   #4
hockmasm's Avatar
i had it on 5 point. now i switched it to center point. is that better?
05-15-2010, 10:47 AM   #5
QuoteOriginally posted by hockmasm Quote
Nothing is inherently better. They all have their uses. Focus and recompose with center point might be better in this situation as the camera's auto focus points made the mistake.
05-15-2010, 11:36 AM   #6
causey's Avatar
Use smaller apertures and give it a bit of negative exposure compensation--the K-x tends to overexpose a bit.
05-16-2010, 10:25 AM   #7
Marc Sabatella's Avatar
It's out of focus - in situations like this, you often need to focus manually to get focus *exactly* where you want - and also overexposed.
05-17-2010, 01:35 AM   #8
Jasvox's Avatar
In my opinion according to this example, the K-x isn't doing anything to your flower. You aren't focusing correctly.
Jason
05-17-2010, 12:09 PM - 1 Like   #9
Here's a similar thread - https://www.pentaxforums.com/forums/pentax-beginners-corner-q/100840-how-redu...ht-colors.html
camera, dslr, photography
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
Weekly Challenge Weekly Challege #104 - "Flowers (B&W)" - Winners ceericks Weekly Photo Challenges 17 08-02-2009 10:30 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
Great video tutorial on making skin tones "glow" slip Digital Processing, Software, and Printing 2 04-02-2007 10:38 AM
All times are GMT -7. The time now is 12:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
