05-17-2010, 04:33 PM   #1
K-x tungsten WB is not a fixed WB
Was shooting some copy work under tungsten, using all manual settings and tungsten WB. Took multiple shots to stitch, but the color shifted significantly between shots. Reviewed all settings to verify, then duplicated the problem. Set WB to manual, and problem did not recur.
Conclusion: in tungsten WB mode, the K-X is still applying auto WB corrections.
Anyone able to confirm/deny?
Edited to add for anyone searching this thread: Custom Menu 2, Item 9: Auto WB in tungsten light. (found it at random a month later)
05-17-2010, 07:34 PM   #2
Ira
QuoteOriginally posted by kxr4trids Quote
I think it's just using auto TUNGSTEN white balance.
Tungsten still includes a range of temperatures that the camera tries to interpret.
05-17-2010, 07:57 PM   #3
Just1MoreDave's Avatar
Yes, the only way to get a fixed white balance is to set one manually. Otherwise, the camera will fine-tune the preset values. On the K-7, it looks like you can tell it not to.
05-18-2010, 12:43 AM   #4
blende8's Avatar
Manual p. 192 (K7):
AFAIK, the Kx does not have this feature.
auto, camera, dslr, k-x, photography, settings, shots, tungsten, wb
POLL: Who has front-focusing in tungsten lighting? soccerjoe5 Pentax DSLR Discussion 17 02-01-2010 05:06 AM
Can K20 be adjusted for indoor Tungsten light? philbaum Pentax DSLR Discussion 12 07-22-2009 05:40 AM
spiral bulbs and tungsten lighting ibdull Photographic Technique 35 04-05-2009 09:05 PM
Tungsten WB with daylight??? FuzzyOne Photographic Technique 20 01-09-2009 11:16 PM
AF, the K10D and tungsten lights hudsong Pentax DSLR Discussion 5 01-27-2008 05:03 PM
All times are GMT -7. The time now is 07:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
