05-17-2010, 10:25 PM   #1
Did anybody install firmware 1.04 on K20D using Win 7 - 64 bit?
I just downloaded the firmware update 1.04 for my K20D from Pentax website:
Latest K20D Firmware Update : Software Downloads : PENTAX
After I downloaded in my Windows 7 - 64 bit PC,
I extracted the file but then there is this warning that the file might not install correctly. I didn't write down the file name but something with "...win32".
So I assume it must be for 32 bit Windows.
Has anybody tried to install this new firmware update 1.04 to their K20D using Windows 7 - 64 bit? Do you get any problem?
If nobody ever did this I guess I need to contact Pentax USA and ask them directly.
Thank you for the help.
05-17-2010, 10:35 PM   #2
Although I haven't had experience with this specific example, I do know that usually the whole "maybe this didn't install correctly" notice is a load of crap and can be ignored. If the program ends up running, then it did install correctly
05-17-2010, 11:32 PM   #3
On my Windows 7 x64 I did it successfully.
Technically firmware update is simple LHA self-extracting archive, you can unpack them directly on your card.
05-18-2010, 12:41 AM   #4
See my reply in the other forum; added here as reference for others.
Download the version for the Mac if the windows exe does not run. The Mac version is a zip file and can therefore be extracted by any software the supports the ZIP format; this will work on any platform.
Extract it and copy the bin-file to the memory card as per instructions.
05-18-2010, 04:22 AM   #5
I updated my K20 successfully using Windows 7 64 bit. You do get an erronerous error regarding the firmware exe not installing successfully but the actual bin file is created successfully. I just copied this onto my SD card and updated.
05-18-2010, 09:12 AM   #6
@ Adam: I really hope so. Cross my finger. Because I'll need the camera for my upcoming vacation.
@ HEKPOMAH & robbiec: Thank you for the confirmation. This is what I expect. I think I'll go ahead and do the update tonight.
@sterretje: I've replied you in the other forum. Thx.
05-18-2010, 08:08 PM   #7
Good news: The update for firmware 1.04 on my K20D using file extracted with Win 7 64 bit went successfully.
Thank you for the helps.
camera, dslr, file, firmware, k20d, pentax, photography, windows
ist DS Failed Firmware Install MSsuper Pentax DSLR Discussion 15 11-17-2009 02:00 PM
K110D Firmware fails to load/install ? ? ? ? ? derek45 Pentax DSLR Discussion 2 09-20-2009 08:22 AM
what is the difference bwt exporting to 8-bit or 16-bit tiffs? rdrum76 Photographic Technique 3 01-22-2009 01:51 PM
What update for Win Vista to preview K20D and Silkypix Peter Zack Digital Processing, Software, and Printing 5 10-16-2008 10:03 AM
k20d CD Software doesn't install on Mac amateur6 Photographic Technique 22 02-29-2008 03:47 PM
All times are GMT -7. The time now is 06:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
