05-21-2010, 01:33 PM   #1
slyfox's Avatar
Problem: K20D all-green shot
Hi, can some body tell me what to do with Pentax K20D in case when I start time to time get fully green or white shots. Camera loose control, help only re-loading battery. Name:  IMGP3000.jpg
Size:  30.1 KB Name:  IMGP3003.jpg
05-21-2010, 01:40 PM   #2
I'm going to take a wild guess and say that something inside it broke and that it needs to be sent in. Probably a serious sensor/circuitry problem.
05-21-2010, 02:34 PM   #3
forensicscientist's Avatar
wow...interesting.
I'd try different battery, different SD card...and if you confirm it's consistent, then it surely is something on the sensor or one of the boards. As Adam said, send that puppy in....
Good luck,
05-21-2010, 03:24 PM   #4
cosmicap's Avatar
I had precicely this problem with an Aldi Traveler. It was broke. They replaced it. Good luck.
05-21-2010, 03:29 PM   #5
Senior Moderator
Parallax's Avatar
I think it is a malfunction or perhaps catastrophic failure of a component part, or parts, and/or associated circuitry.
05-22-2010, 07:52 AM   #6
slyfox's Avatar
I have two battery (I have BG2), and two SDHC Transcend, one of them class 6. I think to buy SanDisk Extreme III, because with class 4 I have very often problem (6-10 normal shot), with class 6 not to much (per 100 good shots 2-3 bad).
05-22-2010, 10:21 AM   #7
Get a quote before sending it in, repair charges are usually double the cost of a replacement.
05-22-2010, 12:54 PM   #8
slyfox's Avatar
there are some tests in debug menu, somebody know how they working ?
05-22-2010, 01:19 PM   #9
slyfox's Avatar
I think I have the same: https://www.pentaxforums.com/forums/pentax-dslr-discussion/84546-k20d-freezin...me-number.html
05-24-2010, 04:47 PM   #10
Mine did something similar, started with green bands on a few images (amongst lots of unaffected images), then a green image and nothing I could do would 'fix' it.
New motherboard. Sorry.
I hope you have some warranty left ...
05-24-2010, 05:23 PM   #11
darrenleow's Avatar
I used to get the freezing camera & corrupted image with a Kingston Class 6 8GB SDHC. Had to remove the grip and the camera battery to get it to work normally. After switching to a Sandisk Extreme 30mb/s 8GB SDHC (and subsequently losing the Kingston card) I haven't encountered it since. I emailed Pentax before but they told me to try it out with a different card and without the grip. If I ever run into the same problem I'll send the camera in for a checkup.
05-25-2010, 10:23 AM   #12
slyfox's Avatar
I have talked with two different services centers of pentax where one of them told me that this not a matrix, and not a sdhc card and nothing else. Second told that this happened only when water inside. But to clear situation told me try to use only SanDisk and if this happen again send it to service.
p.s.
advised to forget about Transcend
camera, dslr, k20d, photography, time
Problem with K10 - Green pictures arratetxu Troubleshooting and Beginner Help 10 05-05-2010 03:18 AM
Manual lens + K20D makes green? imtheguy Pentax SLR Lens Discussion 4 06-15-2009 09:55 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
K10D Problem - 1 shot has a short horizontal line jnorth Pentax DSLR Discussion 8 05-19-2007 11:44 AM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
