Originally posted by techristian WHICH IS THE CHEAPEST AND BEST WAY to take pictures with my TASCO reflective astronomical telescope using my *istD camera. Which adapter(s) do you recommend? I also have a refractive telescope as well. How do I connect to the eyepiece?
Dan
There are those adapters from eyepiece mount to T2 thread and then you add a simple T2-K-mount adapter for the camera (as posted above). Which size of T2-eyepiece tube adapter you need is a telescope specific question. Currently most lower end scopes use 1.25-inches tubes and bigger/better scopes use 2-inch drawtubes/focusers.
But some older scopes also use the much smaller 0.965-inches focusers. These last ones will vignette visibly with your camera as the diameter is so small and the overall length of the focuser + adapters is quite long.
Some scopes already have an integrated t2- thread at the focuser end - perhaps you are lucky there?
My question would be, what do want to photograph through that scopes? If you want to take astronomical images through the scope, your tracking mount should be very good (unless you take images of the Sun and Moon exclusively).
Ben
