05-23-2010, 07:41 AM   #1
k-x overheating in video mode
do they have a solution for this? other than just dont use it for more than a few minutes at a time
card im using : SanDisk - Ultra II 16GB
05-23-2010, 07:55 AM   #2
theperception2008's Avatar
Location: Łódź, Poland and Riverside, California, U.S.A
QuoteOriginally posted by jupzchris Quote
Hi jupzchris,
What is the camera doing that suggests that the camera is overheating? If the camera just stops shooting video after a few minutes by itself, it is not overheating. Simply the buffer is just full. To help mitigate such problems, make sure your firmware is updated which solved most of these problems and if it is updated try using a faster memory card such as the Sandisk Extreme III 30mb/s read/write card. The Extreme III never fail in working :-) I hope that helps.
05-23-2010, 08:02 AM   #3
pbo
pbo's Avatar
K-x does overheat after a while of using Live View/Video - it is shown by a red thermometer in the display (you can also kind of feel the back of the camera being warmer than normal), though I'm not sure whether video stops because of this or because the buffer is full (I always thought it writes as it records, and there's not much lag - at least the write-indicating lamp doesn't blink much after stopping video; I use extreme III cards though)
Don't know a solution to this overheating - don't even have the K-x now but obviously, shutting down live view helps...
05-23-2010, 08:07 AM   #4
red thermometer comes up yea .. doesnt stop shooting video just dont want to run the camera if its goign to over heat ...i normally end up switching out between three cameras and its kinda annoying ;/
05-23-2010, 04:46 PM   #5
rparmar's Avatar
AFAIK all DSLRs do this with video. I have heard mixed results with just ignoring the thermo warning.
08-05-2010, 11:38 AM   #6
Vielleicht mal etwas kühlen bereits im Vorfeld?
Hier weitere Tipps dazu...
08-05-2010, 08:14 PM   #7
Do a search, Nikon and Canon DSLRs do this too.
It's just life with a CMOS based DSLR video setup.
camera, dslr, photography
k-x overheating in video mode jupzchris Video and Pentax HDSLRs 3 05-24-2010 03:38 PM
Pentax K-7 video mode. betozimmermann Video and Pentax HDSLRs 3 03-31-2010 05:59 AM
over heating on K-X video mode kmlo1984 Video and Pentax HDSLRs 5 01-04-2010 07:39 AM
Will using the video-out when in video mode help conserve battery? greenless Pentax DSLR Discussion 2 12-14-2009 02:49 PM
best settings for k-7 video mode? jan rinze Video and Pentax HDSLRs 4 11-25-2009 02:30 PM
All times are GMT -7. The time now is 10:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
