05-23-2010, 05:51 PM   #1
K-7 Sharpness issues
Hi all -
Recently upgraded from my trusty K100D to the K-7, and am fairly dissatisfied with the move at this point. Compared with my K100D photos, the K-7 images generally just seem less sharp. For reference, I am using the same kit lens as I used with the K100D (saving up for an upgrade). I shoot exclusively in manual mode and have shot in all different apertures, shutter speeds, and ISOs, used a tripod, and tried anything I can think of short of purchasing a new lens in an attempt to find a solution. I am having no luck. Is this a common problem? Any hints? Am I missing something?
Thanks for your help in advance. I am open to hearing any ideas..
Nick
05-23-2010, 06:09 PM   #2
Could we see some sample shots? The k-7 has more pixels, so you're likely to notice more of the imperfections in your photos. Were you shooting MF or AF, and with SR or no SR?
05-23-2010, 07:42 PM - 1 Like   #3
hcc
hcc's Avatar
I am sorry to hear your trouble. Most Pentaxians are very happy with their K-7 and your experience is unusual.
I agree with Adam that it would help to see some photos. Also:
- are you shooting JPEG or RAW?
- what are the K-7 settings ? default settings ?
- do you using shake reduction (SR) ?
- what lens(es) did you use ?
A couple of points/comments:
*I note that you mention a tripod. There have been some discussion and threads on SR (Shake reduction) and tripod. Several Pentaxians advised against SR with tripod. (I do not use tripod and would not not comment.)
*If you use SR, do you wait about 1-2s to see the SR 'hand' light appearing ? If you shoot wth SR On and without waiting for the SR light to appear, your shot will be blurred.
*If you use a lens with IS, the camera SR and lens IS do not work together (one or the other, but not both), and yield blurred pictures.
05-23-2010, 07:53 PM   #4
I've read about hi res sensors out resolving the lenses, especially the 'cheap' ones. And this is true for any brand. Hence the version II of the 18-55 kit.
If this is the case (no intent to hijack the thread, but it would be general concern), is it then an absolute must to buy a good lens when buying a K-7?
05-23-2010, 09:15 PM   #5
Wheatfield's Avatar
How are you focusing?
If AF, have you tried adjusting the focus bias to dial the lens in a bit closer?
Here's a little test:
With the camera on a firm tripod, focus the camera with the AF and take a picture.
Now, note the position of the focus ring and very slightly move the focus one way, and then the other, taking a picture at both positions.
See if one of the images is sharper than the AF adjusted picture.
If this is the case, then adjust the AF bias to bring your lens into focus.
05-23-2010, 09:17 PM   #6
QuoteOriginally posted by hcc Quote
These are all relevant points. Once you have satisfied yourself that the camera settings are optimal and that you are using the camera properly, you should calibrate your lens with the AF Adjustment feature. It is quite possible that your lens is suffering from front or back focusing problems on the K-7 that it did not have on your previous camera. Once you have done a proper calibration, you should be more than satisfied with the sharpness of the K-7.
Rob
05-23-2010, 09:26 PM   #7
Evening, I upgraded to the K20 from a K100 just a year ago. I too thought that the Kit lens for the K100 (ver 1) would have resolution problems on the K20 so avoided using it. I finally wound up doing a test and was very happy (and surprised) with the results - although it looks like I deleted them.
I am wondering if there might be a slight front/back focusing issue going on with the camera/lens set. Just thinking out loud.
If you use the 2 second delay with the body on the tripod, SR should automatically be disabled.
05-24-2010, 01:04 AM   #8
Pentaxor's Avatar
check your custom image setting. the K10D, K20D and K-7 have different default setting values. so you need to make the adjustment for the camera.
05-24-2010, 01:47 AM   #9
Class A's Avatar
QuoteOriginally posted by ntlegg Quote
Are you comparing the shots at the same size (say 5x7) or do you "pixel peep"? If you do the latter, i.e., look at a 100% zoom then the K-7 will of course look worse. It has a lot more pixels and everything else being equal the higher number of pixels will show less local contrast.
To check the AF accuracy of your K-7 you may want to have a look at these Autofocus Adjustment Hints.
05-24-2010, 04:06 AM   #10
I think that you will find that the K7 sensor out resolves the original kit lens capabilities, although unless you are looking at a pixel level photo it should still have more detail in it than the K100 offers. The things others suggest are worth looking into. Make certain the lens isn't front or back focusing, make certain there isn't an adjustment in Jpeg development that you could make.
I would get another lens -- whatever you can afford. Maybe a manual focus 50 and compare the two. Should find that it is significantly sharper with that. Oh, and post photos...
05-24-2010, 04:24 AM   #11
Ben_Edict's Avatar
Hi all -
Nick
Just as GrinMode and Rondec wrote: you saved in the wrong place. The old, original kit lens, that came with your K100 was replaced with version II to meet the increased requirements of the higher res sensors.
If you try to look at images from your K100 and from the K7 at the same size (not at the same magnification setting) the image should appear similar.
Some lenses are so much overstrained, that their contrast breaks in completely and then the images are much worse, than on low res sensors, even at the same image size. My copy of the Sigma 24-135/2.8-4.5 being a "good" example of this.
Ben
05-24-2010, 05:09 AM   #12
Class A's Avatar
QuoteOriginally posted by Ben_Edict Quote
I find this hard to believe. Even if a sensor already out resolves a lens, making it resolve more, will still improve the image quality (because MTF curves are multiplied in an optical chain). Something else must be going on, if you really observe a degradation when going to a better resolving sensor.
05-24-2010, 07:31 AM   #13
henryjing's Avatar
Acctually I have the same problem about the K-7 sharpness, anybody has a suggestion of K-7 in-camera setup?
05-24-2010, 09:52 AM   #14
Just1MoreDave's Avatar
QuoteOriginally posted by henryjing Quote
This is important advice so I'm repeating it:
I noticed that Adobe Camera RAW 5.5 was applying sharpening in the converter for the K-7, and I had turned it off for the *ist DS. That's about the extent of my sharpness comparison so far.
05-24-2010, 12:13 PM   #15
alexeyga's Avatar
It's fairly easy to check the AF accuracy on K7...
1)setup a target (closer to the camera is better) (the famous 3 AA-batteries test or the plain and simple any TEXT at 45 deg)
2)setup the camera on a tripod and don't forget to turn the SR off
3)if you have a remote, use it, if not setup the camera into 2sec timer mode.
4)open up the apperture
5)take a shot looking throught the VF
6)throw the lens out of focus
7)take a shot using LV using the AF-button to focus
8)throw the lens out of focus
9)still in LV, switch to MF, zoom-in 100% on your target and focus by hands... until you see that it's dead sharp! take the shot...
One of these pics will tell you the truth... But carefull.... there are somethimes things that are best to left unknown...
camera, dslr, k-7, k100d, lens, photography
k-7 sharpness / fine sharpness / fine sharpness 2 mattdm Pentax DSLR Discussion 10 12-12-2010 08:10 AM
Help with k-7 sharpness shaun2k Pentax DSLR Discussion 14 02-11-2010 06:25 PM
Sharpness VS Fine-Sharpness in k20d wasim_altaf Pentax DSLR Discussion 8 10-12-2009 11:41 AM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
All times are GMT -7. The time now is 08:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
