Originally posted by wildman Put t ring adapter on camera body without lining up blades on mount properly - did not line up red dots.
Now I can't get it off. It releases on one side but not the other.
Any ideas?
Seems strange it could go on so easily but not come off.
Any help appreciated.
Wildman
I did that with my K10D, once. I was in San Diego, about to board a cruise ship for seven days. I put my 500mm mirror lens on incorrectly. I think that I had the mount rotated 1/3 of the way out of "sync".
I fought with it for about half an hour and then went to a camera shop a few blocks away. They were sympathetic, but not much help. Eventually, I ended up getting it off myself, there in the store.
I hope you're sitting down. This is scary. Basically, I simply forced it off. I was able to tilt it a little and get one of the three sections of the bayonet to start through the opening. It jammed up and wouldn't go any further. At this point, I figured that the camera was useless as it was and I used a flat-bladed screwdriver and carefully pried it off.
The good news is that the metal on the t-mount adapter was softer than that used on the camera's lens mount. My forceful removal bent one of the ears on the t-mount adapter, but did no apparent damage to the camera. Whew!!! This was two years ago, and I have not noticed any problems since then. The adapter even continues to work, as well.
As always, your mileage may vary. Good luck.
