05-25-2010, 11:10 PM   #1
TAP's Avatar
Help! KX Pop-up Flash
Hello All,
This past weekend, I took a spill while shooting at an event. Luckily I bypassed my natural instinct to brace my fall and instead, braced my KX for impact. My camera was fine; I can't say the same for my hands and face [haha].
Anywho, the next day, I fired a few shots [some with the pop-up flash] just to make sure everything was in working order; success. I popped the flash back down and put the camera away.
Now, regardless of shotting mode, my flash will NOT pop up- even when I press the button.
Where do I go from here? I am somewhat experienced in doing minor at-home repairs. Is this the kind of thing that I might be able to fix on my own? Or is my best bet to take advantage of the warranty and send it In? My assumption is the latter but I wanted to get a second opinion before jumping to conclusions.
Thanks in advance,
Pat
05-26-2010, 01:03 PM   #2
TAP
TAP's Avatar
Alllllllllllllllllrighty, I guess I'll be sending it in.
05-26-2010, 01:06 PM   #3
KxBlaze's Avatar
I would highly suggest sending it in. It sounds like the actual release lever (not the flash button itself) is not activating when you press the flash button, so unless you can take the camera apart to get to that lever and feel comfortable doing it, I would let Pentax do it, because if for some reason Pentax can't do it or messes up they will replace it. If you try to do it and are unsucessful, that will void the warrenty.
camera, dslr, flash, kx, photography, pop-up
K7 pop up flash @#%! ordinaryimages Pentax DSLR Discussion 12 04-05-2010 02:55 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
K-7 Pop Up Flash Higher? lawsonstone Pentax DSLR Discussion 3 06-20-2009 11:39 AM
Bouncing Pop-Up Flash... R.ticle One Photographic Technique 5 03-03-2008 06:42 AM
Pop-up flash diffuser? lapeen Flashes, Lighting, and Studio 16 09-21-2007 02:44 PM
All times are GMT -7. The time now is 04:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
