05-27-2010, 05:38 PM   #1
*ist blurry viewfinder repair replacement
I had some water enter my viewfinder/diopter (Oregon) and before it dried, I tried cleaning it too hard resulting in a nice blurry patch in the center of my viewfinder lens. BE WARNED to clean those VERY GENTLY.
Anyway after reading some other posts and courtesy of Owen sending me a replacement viewfinder, it was a rather simple fix. Owen previously posted that he paid $12 for a replacement from Pentax - let me know if anyone orders one and what the part number might be. Here's the original thread with an exploded parts diagram.
The fix: (this was for my spare istDL but imagine others should be similar.
Remove 7 screws - Two under the popup flash, two beside the viewfinder. The outermost one inside the battery compartment, one below the dial on the left side of camera (viewed from back) and one below the neck strap tab on the right.
The screws are of various sizes, keep note of which goes where.
The top of the camera will now lift off, but is still attached by wires and ribbons: see picture below. The view finder assembly is probably removable, but the outermost lens is easily changed without that step. The outer piece of black plastic is held on with double sided tape, pry this cover gently off. (This is already removed in the camera picture, see pic of separate pieces below) Then there are four clips that hold the outermost viewfinder lens in, gently undo those four clips, the old will slid out, pop in the new one, and put it back together.
thanks to Owen..
Rick
C860L,D360L  Photo
C860L,D360L  Photo
05-27-2010, 05:40 PM   #2
Should I move this to the DIY section in the articles? Seems like more of a reference than a discussion to me
05-27-2010, 11:03 PM   #3
where ever it belongs is fine - yeah meant as a reference that I couldn't find when I wanted it...
(you can delete this post if you move it)
05-28-2010, 11:36 AM   #4
Copied it to here: https://www.pentaxforums.com/forums/pentax-dslr-camera-articles/102950-*ist-b...placement.html
This thread can remain here for discussion.
camera, clips, dslr, lens, owen, photography, replacement, screws, viewfinder
Ist DL Viewfinder display/symbols blurry loudel Pentax DSLR Discussion 3 05-28-2010 03:53 AM
*ist D repair questions alohadave Pentax DSLR Discussion 1 09-28-2009 02:47 PM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
Lens group replacement repair - DA* lens - thoughts? ksignorini Pentax SLR Lens Discussion 8 07-20-2008 05:53 PM
repair advice inquiry - front focus on *ist DS q10 Pentax DSLR Discussion 5 03-08-2008 04:43 PM
All times are GMT -7. The time now is 02:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
