Originally posted by JohnBee I found that if you can't achieve clean ISO3200(no compromise) prints with your camera, then your most likely not going to be very satisfied. Though ideally, a working range between ISO200 to 4000 was what worked best for me.
Wow, ISO 3200 and NO COMPROMISE? Really? What camera did you get? If there are no compromises at ISO 3200, do they even bother to include the other, apparently unnecessary ISO options, like 1600, 800, 100? I wish they would get rid of those lower sensitivities, cut the cost of these cameras by a couple of thousand dollars, and let us buy ND filters instead. :-)
Look, I'm happy that you could afford a full-frame camera and happy that (apparently) you like it. I've said it repeatedly: If I had money to burn, I'd order a couple full-frame cameras today. I'd probably even use 'em to shoot my next wedding. If I win the lottery, I'll probably buy a couple digital medium-format cameras, too.
But anytime somebody uses the words "no compromise" in a discussion like this, I know there's some special pleading going on, and often, they're trying to justify an expensive decision they've made. That's cool. I do the same thing. I mean, I justify my expensive decisions. But what I don't do (or try not to do) is pretend there are no compromises.
There's simply no such thing as "no compromise" anywhere in Cameraland. Cost and size are major compromises.
A 36x24 camera may produce significantly less noisy photos at, oh, ISO 3600 and above than an APS-sensor camera. But it does not produce "clean" images. I don't speak from personal experience, as I don't own a 36x24 camera.* But take a look at the examples shown in every 36x24 camera review at
dpreview.com. ISO 3200 is noisy. ISO 1600 is noisy. They may be usable, but they're hardly "clean." They're simply "clean enough." But that's the $64,000 question: what's "clean enough," given what your clients expect, what you can afford, what's technically possible? I've made very nice prints from photos taken with a K20D at ISO 2000.
The compromise is, you get better performance at ISO 3200 (say) but the 36x24 camera costs four times as much and is much bigger and heavier.
Moreover, it does NOT produce images that are significantly better at ordinary ISO levels, such as one can use when shooting in good light, or with well-governed flash. My little Panasonic LX3 is very noisy at ISO 800; but at ISO 100 or ISO 80, in good light, it produces images that rival those I can take with my K20D. And the LX3 cost me less than $400 and fits in my pocket. I wish I were a millionaire, not just so I could buy all these expensive, beautiful cameras, but also so I could post a reward: $50K to the person who can tell me, in a small book that I would publish, of a dozen photos taken at ISO 100 by good photographers, which were taken with 36x24 cameras and which with APS-sensor cameras.
So every choice involves a compromise. That's why it's so extremely important to understand the concepts of (a) what's just barely good enough, at the low end, and (b) what's better than I need or can afford at the high end?
Will
*NOTE re "I don't own a 36x24 camera". Well, I guess I do: My Nikon 35mm film camera (N65). Nice camera. But shooting ISO 1600 with Ilford film, it's not nearly as nice as my K20D.
