05-31-2010, 03:41 PM   #16
tokyoso's Avatar
Stop imaginging you need to press the Green button every time you take a shot using a manual lens. Light doesn't normally change nearly that often. Choose an aperture and shutter speed that works for the room and then *leave them alone* while you shoot. At most maybe turn shutter speed up or down a click depending on whether your subject is getting direct light from a lamp or not.
Also, don't be shooting only at ISO 100 or 12800. Expect most indoor locations to support ISO 1600 with a reaosnably faster lens, ISO 3200 or at worst 6400 if you're limited to f/4 or f/5.6.
Noise happens. That's what NR is for. But too much of it results in the smoothing away of detail. If you really care about the results, you'll do your NR in PP rather than try to guess which of the handful of in-camera settings will sort of come closest to what you could have done much more effectively in PP. And yes, that means doing as little as possible in camera - and ideally, shooting RAW.
i still cant get my software to read K-x raw files correctly. any pointers?
05-31-2010, 04:20 PM   #17
QuoteOriginally posted by tokyoso Quote
Hmm... that's really weird... try reinstall? if not I use also UFRaw UFRaw - Home
It can be used for just about any type of raw... but I don't use it for PP.
EDIT: Also nice for Gimp because in addition to being a stand alone it can be used as a plugin for Gimp.
05-31-2010, 04:25 PM   #18
Thanks for the tips on the M and with the ISO.
I shoot RAW ! but then it also produces a JPG. Hmm... so that means... I have a noise reduction JPG and w/e effects it has, plus a RAW I can then produce a new JPG if I don't like the new JPG. OKAY!
;/ gotta balance the NR...
05-31-2010, 05:05 PM   #19
Marc Sabatella's Avatar
What do you mean "it produces a JPEG"? The camera does? only if you have the RAW+JPEG mode selected. There's really no good reaosn to use that mode. Shoot RAW, do your PP if necessary, then batch convert to JPEG those worth converting (for me, maybe a third of my images get converted).
As for software, older programs won't support newer cameras. not sure what software you have, but check their web site to see if there are any updates to support cameras that came out since the software was originally released. Usuaully companies put out updates to support new cameras a few times a year; most software should support the K-x by now.
05-31-2010, 05:40 PM   #20
Yeah I have it on RAW+ mode... hmm I guess I should shoot just RAW. Lets me take more pictures, and saves more time and camera process usage. Yeah... probably less than 1/3rd for me.
05-31-2010, 07:00 PM   #21
RioRico's Avatar
Threadjack. I think I've ID'd most of the Nobel laureates. Top row: Desmond Tutu (South Africa), Dalai Lama (Tibet), Betty Williams (Northern Ireland Peace Movement). Bottom row: Jody Williams (International Campaign to Ban Landmines), Rigoberta Menchu (Guatemala), unknown guy, and Shirin Ebadi (Iran). Any idea who that unknown guy is?
06-01-2010, 04:52 AM   #22
tokyoso's Avatar
Thanks, I may have to get a new updated version.
06-01-2010, 08:25 AM   #23
Good job! I never remember all the names either, but I looked it up (from the 2006 "PeaceJam"): Adolfo Perez Esquivel.
06-01-2010, 08:29 AM   #24
QuoteOriginally posted by NecroticSoldier Quote
would you rather use a slower shutter speed and try and get by with it or bumping the ISO up to 6400+ or... not shoot it at all?
If that's the only options, take the shot with the higher ISO. What do you have to lose? You can process out noise. Good luck processing a blurred image.
Or, try both and see which works best.
Process the noise as best as possible, or lower the ISO and under-expose it, then correct it in photoshop (which will also lead to noise processing). Maybe you'll end up with a usable image.
06-01-2010, 01:40 PM   #25
GerryL's Avatar
The Dalai Lama must have a name?
All those who become Dalai Lama are called Dalai Lama, but they all have their own respective names.
06-01-2010, 03:01 PM   #26
RioRico's Avatar
QuoteOriginally posted by GerryL Quote
Tenzin Gyatso is the 14th Dalai Lama. And Sr Esquivel is from Argentina. The Wikipedia List of Nobel Peace Prize laureates didn't have his picture, so I missed ID'ing him.
camera, dslr, iso, photography
All times are GMT -7. The time now is 06:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
