06-05-2010, 10:28 AM   #1
WMBP's Avatar
*ist DS "memory card error" - card won't format
I formatted an 4 GB SD card on my new Panasonic Lumix DMC-LX3, then put the same card into my *ist DS. Got an alert saying "Memory card error," which I did not find surprising. What surprised me is that I am unable to reformat the card in the *ist DS. Camera's working fine. I have another card in there (one that's never been in the Panasonic) and it works fine. I was also able to take the problem card, format it in my K20D and take a photo there. So it seems to be some combination of the card and the camera.
It's not a pressing problem. As I said, I can simply use different cards. But I'm curious. Is there a way to force a card to format, sort of a low-level format for the *ist DS?
Will
06-05-2010, 10:31 AM   #2
Is it because its an sdhc card? Those might not be supported by the DS.
06-05-2010, 10:35 AM   #3
Wheatfield's Avatar
Presuming the DS supports SDHC cards, you could try putting the card into a reader and doing a format on it via your computer, and then trying to format it in camera.
I've had good success with this on the occasions that I've had a memory card error in camera.
06-05-2010, 11:13 AM   #4
If I recall correctly, Pentax released a firmware upgrade to support SDHC cards. If you haven't upgraded you camera, this is the error you get.
06-05-2010, 11:20 AM   #5
WMBP's Avatar
Thanks to all of you, starting with Adam. Yes, it is an SDHC card. I could have sworn that I'd used this card in the DS before, but perhaps I'm wrong. I'll check out the firmware and see if that makes a difference. I'm trying to sell the DS and I guess I should make sure that it's got the latest firmware so the buyer doesn't have to worry about that.
Thanks, y'all.
Will
04-04-2016, 06:07 PM   #6
Gentleman Thanks for all of your comments I was able to get my ist DL to work correctly once I got the correct SD card and also updated the firmware to 1.03.
04-05-2016, 04:39 PM   #7
FozzFoster's Avatar
I ran into this problem too,
Make sure that you use a non-SDHC card to upload the firmware too.
I know it sounds silly, but I used an SDHC card to try and update the firmware to read SDHC cards! Hah.,
I found an old card, updated my firmware, and the camera now reads the new cards with no problem.
Best of luck,
*ist, *ist ds, camera, card, ds, dslr, fine, format, panasonic, photography
K20 "Memory Card Full" Error message FHPhotographer Pentax DSLR Discussion 2 02-10-2012 10:22 AM
Memory card "card not formatted" error mickc Pentax Camera and Field Accessories 7 07-12-2011 08:49 PM
Pentax K100D - "memory card error" fingersmalone Troubleshooting and Beginner Help 2 02-19-2010 08:40 PM
"memory card error" after K10D fell: prognostic? nicolas1970i Pentax DSLR Discussion 3 07-07-2009 12:03 PM
A picture with *IST DL with a Sigma DG500 super with "a better bounce card" Jakerlund Post Your Photos! 3 07-20-2007 06:48 PM
All times are GMT -7. The time now is 03:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
