I'm not aware of any CMOS battery in a camera, although one might exist in some I suppose. Every desktop computer I've ever worked on has had one though, but it's a lot more accessible, and I've had to replace dozens. The time stamp is probably stored by means of a capacitor, which acts as a small battery of a sort. The capacitor stores an electrical charge until the circuit needs it. This is why if you open up a TV or a tube type guitar amp and touch the wrong thing it can kill you. They hold very high voltage for a long time, several months.
The capacitor in a camera holds a much lower charge, probably no more than 3 volts. (CR2032 battery is 1.5V I think) The problem is that the capacitor can only hold power for a certain time. If I take the batteries out of any of my cameras for 5 minutes, I have to reset the date. If I swap batteries in less than a minute, it stays put. I usually take less than 30 seconds.
I'm guessing here, but either you're taking too long to swap batteries or a capacitor is getting weak.
