06-06-2010, 09:15 PM   #1
cosmicap's Avatar
K200D malfunction
Last week while on holiday I switched the camera on and the LCD very briefly showed its knowledge before going blank. The camera failed to wake up. Every time I switched on was the same. I took out a battery and reinserted - same. Gave up on the photo and sat glumly in the car fiddling with every conceivable combination. Took out the memory card and reinserted and back to normal. Phew! Anyone had a similar experience or explanation?
06-06-2010, 10:03 PM   #2
Jonathan Mac's Avatar
Sounds like either a faulty battery that took the voltage too high momentarily, or a loose connection within the camera. If it's all ok now, I wouldn't worry about it. (But if it happens again...)
06-06-2010, 10:13 PM   #3
Jools's Avatar
I've had this happen to me a few times.
But always when using batteries that turned out to be inadequate. Once I change to eneloops it all goes back to normal.
That's why I stick with eneloops 100 percent of the time. They have never failed me since. For whatever reason the combination works marvels.
Now it could be something else, (hopefully not) but just my 2cents. Jools.
06-06-2010, 11:56 PM   #4
cosmicap's Avatar
QuoteOriginally posted by Jools Quote
Hi Jules: They were in fact Eneloops, with about 400 pics on the clock since last charge. Since then another 150 or so pics and camera still shows fully charged. I wonder if Jonathan Mac's suggestion might be close. Hoping it's a once off whatever the cause.
06-07-2010, 07:51 AM   #5
ChipB's Avatar
Since the problem went away after taking out and reinserting the memory card, sounds like a bad connection. I'd keep an eye on THAT card - cards do go bad and can cause some strange stuff to happen.
06-07-2010, 06:11 PM   #6
Perhaps there was a faulty connection with the memory card door?
With my K200d, the camera won't turn on if the door is open. It's possible your cam though the door was open for some reason, so it didn't turn on.
06-08-2010, 10:54 PM   #7
cosmicap's Avatar
QuoteOriginally posted by Kryosphinx Quote
You are quite right - that recreates the effect precisely. I'm sure I'd have noticed if the door had been open. I'd say it wasn't, but the effect is spot on.
camera, dslr, photography
K20D sensor malfunction tibi Pentax DSLR Discussion 17 09-09-2009 11:47 PM
Shutter Malfunction on k200 mtroute Pentax DSLR Discussion 7 07-15-2009 03:01 PM
K7 bug, temp malfunction or settings...?! LosAnJulien Pentax DSLR Discussion 3 07-10-2009 10:19 PM
Did anybody meet malfunction of Sigma HSM jianshi Pentax SLR Lens Discussion 1 03-20-2009 04:12 PM
Card malfunction Warblingostrich Pentax DSLR Discussion 2 01-22-2008 02:35 AM
All times are GMT -7. The time now is 01:58 PM. | See also: NikonForums.com, part of our network of photo forums!
