06-07-2010, 12:59 AM   #1
Blue images in k2000
Hi all,
I recently purchased a k2000 from a member of this forum. The camera seems great and I have a Quantarray DA 28-90mm on it, and 2 manual lenses (not all at once mind you )
So, a few weeks ago, while messing with the aperture ring on the DA lens, it started taking all Blue photos, till I switched back to 'A'.
Recently, I bought a f/1.7 50mm prime lens (manual). Taking pics with it I got a blue image as well.
Then this weekend, I was shooting with the DA lens and one of the images was blue. I can't figure out why...
I'm attaching 2 examples.
PENTAX K2000  Photo
PENTAX K2000  Photo
06-07-2010, 02:45 AM   #2
kiwi_jono's Avatar
Are you sure that the White Balance (WB) is not set to indoor incandescent?
I have made the mistake of leaving my K-x on this and forgetting several times with very similar results!
06-07-2010, 03:40 AM   #3
StarDust's Avatar
This is clearly a white balance problem, it is compensating for too much yellow such as (primarily) indorrs or evenings where the scenary is dark.
Your white balance is calibrated wrong, check the settings in your camera.
06-07-2010, 04:12 AM   #4
Definitely looks like some how you got your white balance changed to tungsten. Should be able to fix it in postprocessing.
06-07-2010, 07:46 AM   #5
Marc Sabatella's Avatar
According to the EXIF, it appearsth WB is set to "manual" - you must have been experimenting with setting WB manually. As others have said, set it back to auto. Or if you are going to mess with it, you need to set it properly for the type of light. The aperture ring is a red herring here.
06-07-2010, 04:45 PM   #6
I believe WB was set to auto..
That's very weird, I'm almost positive I had the WB set to auto. Perhaps that is why it did that for only one picture? If I had the WB set wrong manually every picture would have been blue, no?
I'll take a look at the camera again when I get home tonight.
Thanks everyone! If it is an issue with WB being set to auto, should I be setting it manually?
06-07-2010, 05:09 PM   #7
Not in general, no. The only time auto WB generally has problems is when dealing with very strongly colored light - like tungsten lighting. Then it generally won't try hard enough to remove the storng color cast. But no need for manual unless you really really want to - just using the tungsten preset should be fine.
camera, da, dslr, images, k2000, lens, photography
K2000 Duane Pentax DSLR Discussion 6 12-20-2009 05:28 PM
Night Blue sky, blue see Rense Post Your Photos! 11 10-10-2009 01:01 AM
A variety of images with FA* 200/4 Macro (no bugs) - VLF competition images Marc Langille Post Your Photos! 28 08-22-2008 07:28 PM
High ISO concert images with Tam 28-300 (Images) jsundin Post Your Photos! 2 07-05-2007 08:19 AM
A few K10D tourist images of Italy (9 images, about 200kb each) volosong Post Your Photos! 2 04-24-2007 04:29 AM
All times are GMT -7. The time now is 10:54 AM. | See also: NikonForums.com, part of our network of photo forums!
