Originally posted by Engi_Nerd None of the above has proven effective in getting the camera to recognize my card, yet it works in every other device I try. New cards function fine. I noticed quite a bit of wear on the contact pads of the card in question. Could my repeated removal and installation cycles (MAYBE 24 total) of the card into the camera have damaged the contacts so that it no longer make a proper connection? No one has had this happen?
One method or suggestion will get your K-x to work with your SD card, send it to Pentax
. It's 6 months old, I presume has a warranty. Get your monies worth out of it. The turn around time when sending it in can be as quick as two weeks.
With a problem such as that I would never fill great about the dSLR. I would always think there is a problem waiting to materialize and ruin the camera.
Serious why not let the most highly skilled techs you can deal with in regards to your K-x have a look at it. In a few weeks or so you will be
BTW I have been using some of my SanDisk SD cards for years with no problem. As all my cameras used them except my old Kodak DC5000 that used a CF card. And its 10 years old card is still working. The only problem I have ever had is the lock tab on the SD card coming off, never a contact problem in any device and with cards 2 or more years old.
Point?.... I don't think you put enough wear on the card to cause and problems, its time to send it in as I said before...
